02-19-2019, 04:30 AM | #1 |
Dyno Show Queen LOL
Zl1 cradle fit the SS?
I was wanting to know will a complete zl1 cradle fit the SS both are M6. What would be the differences or to make it work. I tried to look for a similar post but no luck.
02-19-2019, 09:17 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Rear cradle? What diff? Keep in mind the ZL1 = SS 1LE in this area, apart from the halfshafts.
02-19-2019, 09:54 AM | #3 |
Dyno Show Queen LOL
Yes rear.. maybe just the diff, axles, and drive shaft then..
03-05-2019, 11:40 PM | #4 |
the ediff in the ZL1 and 1le wont work in a non ediff car. the cradle will bolt in but the it will be a open diff. cant make it work.
01-12-2023, 07:43 PM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
it a bummer that this won't work I believe the ediff control module is actually on the rear subframe, it just can't talk to the bus without GM magic. I guess it would "work" if there is an aftermarket Torsen diff...
Clearly the controller can be flashed: https://gmauthority.com/blog/2018/07...sh-for-ss-1le/
