Old 07-17-2021, 02:25 PM   #1
19 2SS
Drives: 2019 camaro 2ss
will it fit?
my wheels are 20x10 et20 and 20x11 et43, im currently running 285/30/20 and 305/30/20, the 305/30/20s are hard to find in the nitto that i run and the toyo\mickey radials only come in 305/35/20s, no 30..
Is anyone running or know if i can run 285/35/20 and 305/35/20 with these wheel sizes and offsets?
Also is anyone running a 315\30\20 with these offsets? what would I run in the front with that rear?
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 07-17-2021, 02:43 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
https://www.willtheyfit.com/
Old 07-17-2021, 03:38 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I don’t think you can run 285/35 on the front or they will hit the strut towers. 275/35 is probably the best bet on the front.
305/35 and 315/30 should both be fine in the back. I believe member Arpad (and probably others) has 315/30 out back with no issues (with 275/35 up front).
Old 07-17-2021, 03:47 PM   #4
19 2SS
just spoke with him thanks again!
