07-01-2021, 10:01 PM | #1 |
topkat
Drives: Red 2017 SS camaro Join Date: Jul 2018
Led back up led bulbs and harnessi
I can’t find the part number for the back up led light bulbs and resistor harnesses ,seen it before on the forum but I can’t find it anywhere. Thanks any help, topkat
07-01-2021, 11:11 PM | #2 |
07-02-2021, 09:05 AM | #3 |
topkat
Thanks for the info, one issue though, it says bulbs are sold out!! So I guess I can purchase the bulbs somewhere else, I need the bulb size or part number if anyone knows that, again thank you .
07-02-2021, 10:27 AM | #4 |
Here is an alternative from trusty forum vendor Phastek: https://www.phastekperformance.com/2...o-6-prled6.htm
07-03-2021, 01:11 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Don't buy the phastek ones they are absolute garbage.
07-03-2021, 07:25 AM | #6 |
topkat
Thanks for info folks!!
07-03-2021, 10:43 AM | #7 |
Interesting. I have the Gen5DIY kit and it's flawless, plus I bought several items from Phastek over the years with never an issue. I thought this was a safe recommendation, sorry if its quality is not up to par.
07-03-2021, 02:42 PM | #8 |
The Gen5diy kit is the way to go. The resistor for the phastek kit never worked properly and after several attempts of trying to contact Phastek via email I just said screw it and bought the Gen5diy kit and never had an issue. I've been hit or miss with Phastek so they're kinda the middle of the road for me when it comes to ordering parts.
07-07-2021, 08:30 AM | #9 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Reason I ask is I just put a Gen5DIY harness on mine and the reverse LED bulb (Morimoto X-VF bulbs) on the side it's installed on is dimmer than the other side. Ordered another set of more generic reverse LED bulbs, same issue still.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
07-08-2021, 07:38 AM | #10 |
Drives: 2018 Camaro SS Join Date: Aug 2020
i have the phastek and it works fine. maybe you just had a bad one. it can happen.
2018 Camaro SS - Hyper Metallic Blue |
07-08-2021, 12:02 PM | #11 | |
07-08-2021, 12:04 PM | #12 |
07-08-2021, 12:14 PM | #13 |
That's what it is suppose to do, but I assume your Phastek didn't work as it was suppose to? Didn't know if it did anything else weird, like my harness.
07-08-2021, 09:06 PM | #14 |
