Old 07-17-2021, 02:31 PM   #197
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Originally Posted by Blackmonba6Gen View Post
That’s the correct number. You may save a few dollars by going to the corvette forums, there is a few selling the gray cover. I bought mines between $100-120 from there. I recently hydrodipped mines as well to match the carbon fiber theme of the car. Im also impressed with how my FBO setup came out, I can’t wait for track days.
Blackmonba: Where did you get the cover for the electrical cover?
Old 11-17-2021, 09:02 AM   #198
6speed_maro
Drives: 2017 camaro ss manual
LT2 INTAKE
Originally Posted by Redlinez View Post
Let us know if you find out it needs other hardware ie bolts/etc. Thanks for your awesome work and post!
It in fact doesn't, all you need is some shaving on the bottom, a hole in the back for the brake booster (make it around the same area your stock one was). Got this intake for my 6 and my boy had it done in no longer then an hour and a half.
If you're not mechanically skilled, i would highly advise bringing it to a trustworthy shop. Better safe then ruining your intake.
2017 camaro SS- LT2 Intake, E85 flex fuel, Corsa extreme axle back, Cat/2nd cat delete, K&N CAI, BMR lower trailing arms
Baseline dyno- 412hp and 420t to the wheels, will have a separate dyno reading for LT2 intake and flex fuel Friday afternoon.
6speed_maro is offline   Reply With Quote
Old 11-19-2021, 04:49 PM   #199
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Your car being a manual and typically dynoing 10-15 RWHP more than a 8 or 10 speed auto, my car with the LT2 intake and a secondary cat delete mid pipe had a RWHP of 421 and 431 lbft of torque did reasonably well , with e70 flex fuel it went to 441 and 445
lt4camaro is offline   Reply With Quote
Old 12-10-2021, 12:48 PM   #200
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Question: Would it be possible to fit the LT2 manifold with the GM strut tower brace if the ribs on the top of the manifold were shaved down underneath where the tower brace would interfere?
Spaceme1117 is offline   Reply With Quote
Old 12-10-2021, 03:15 PM   #201
lt4camaro
lt4camaro's Avatar
I believe there was some posting on this forum related to just that with pictures. You can do it by shaving the ribs in the middle of the intake or make a nice 1/4 inch shave job on the Brace itself.
Old 12-10-2021, 09:53 PM   #202
Kerry
Drives: 2019 2SS Camaro
Works well on my vert
Kerry is offline   Reply With Quote
Old 01-15-2022, 12:32 PM   #203
Maroman17
Drives: Krypton green
Has anyone established themselves as the go to porters for the LT2? Any members here porting them and a 95MM as a combo? Pray is saying he's not onboard with it as his max effort LT2 with stock TB vs a stock MSD is down 21 peak hp.
I was wondering the same thing
Maroman17 is offline   Reply With Quote
Old 01-26-2022, 08:41 PM   #204
RoaringV8
Drives: 2017 HBM Camaro SS 1LE Camaro
Installed the LT2 intake and Roto-Fab Sound Tube Delete CAI on my SS 1LE this weekend. I'm also using the LT5 TB with the Soler 95 to 87MM TB adapter. Ordered the LT2 intake from GPI with the appropriate fitment mods. Retained most of the foam aside from the section over the fuel pump. Slid in and bolted down pretty nicely. For those of you with the strut tower brace, I used 5/16 washers (3), which I bought from Home Depot, under each bolt to help raise it up to clear the top of the Intake Manifold. Two washers worked, but it was still a little too close for my liking. I also purchased (2) M8 1.25 x 30MM. I believe the stock bolts on the strut tower are 1.25 x 20MM which is too short when you add in the washers.
RoaringV8 is offline   Reply With Quote
Old 01-27-2022, 08:30 AM   #205
lt4camaro
lt4camaro's Avatar
Is the intake side of the 95 mm throttle body the same diameter regarding the intake tube and seal that clamp to it.
Old 01-27-2022, 08:50 AM   #206
Spaceme1117
If I get the LT2 manifold, I will likely shave down the ribs a little bit where the strut tower brace is in addition to a few washers for spacing.
I figured that with spacers, the bolts would be a little too short; the factory bolts are a bit short.
Old 01-27-2022, 09:20 PM   #207
RoaringV8
There is a rubber sleeve that goes over the end of the throttle body that pretty easily expands to fit over it. I didn't measure the size of the intake elbow to know if that's exactly 95mm. I looked on Roto-Fab's site and it doesn't specify the size. Not sure if that answers your question.
Old 01-28-2022, 07:56 AM   #208
lt4camaro
lt4camaro's Avatar
Sorry, I asked the question wrong, is the intake side of the 95mm throttle body the same size as the 87mm throttle body so the intake tube and rubber sleeve and clamp all still fit.
Old 01-28-2022, 08:08 AM   #209
6spdhyperblue
Drives: 6th gen
It fits
Old 01-28-2022, 08:26 AM   #210
lt4camaro
lt4camaro's Avatar
Originally Posted by 6spdhyperblue View Post
It fits
Thank you. Some little research I have run across indicates that on a NA stock application even with a few bolt ons, the 95 MM throttle body doesnt produce any additional horsepower. Have you seen or experienced different results?
