12-04-2018, 01:18 PM | #15 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
*Penske, and even then the only reason would be their regressive valves, otherwise they're...
..."just" very nice traditional shim-stack dampers with low hysteresis. At least Ohlins has the DFV option.
12-04-2018, 01:23 PM | #16 | |
Hot Dog
This comes down to what you're trying to do. Are you looking to bolt-on and immediately go fast? Or are you trying to spend months shaking down and tuning a good setup?
12-04-2018, 02:11 PM | #17 | |
Drives: ISO ss 1le Join Date: May 2018
The thing I’d be worried about at that point is spring rates from ZL1 to SS1LE especially the 1LE zl1 with aero. Would they be too high of rate for the SS? . |
12-04-2018, 02:48 PM | #18 | |
Hot Dog
If you're a driver that can lap quicker on a light fuel tank, then you'll probably be changing the DSSV spring rates by 50 lb/in or so just to suit your style.
12-04-2018, 03:55 PM | #19 |
the girl at gm i was dealing with was telling me about the racecar they had it was a ss body with zl1 1le aero and suspension and brakes very similar to the gt4r cars
12-04-2018, 11:19 PM | #20 | |
Drives: 1LE Join Date: Sep 2017
Voice to text screws up again. But do love it. Let me ask you a couple questions if you don't mind what is your background? Do you have an mechanical engineering degree? Can you elaborate on why you don't like to Penske shocks? Are you familiar with Andrew aquilante? |
12-04-2018, 11:20 PM | #21 |
What's the most amount of camber you can get with a set a spool shocks?
12-04-2018, 11:21 PM | #22 |
The currently running 3.6 in the front right now with my my Maggie ride
12-05-2018, 12:34 PM | #23 |
Drives: 2018 1SS 1LE Join Date: May 2018
This is a great discussion. I am an engineer and have many years experience developing and tuning race cars using a “data driven” methodology and I’m looking forward to a engineer level discussion of shock and suspension options. I’m new to tuning the Camaro and have a lot to learn. I’m very interested in spool valve shocks and appreciate any additional knowledge the resident experts can provide.
