11-27-2018, 06:14 PM | #1 |
Do I need new rotors after 14 track days?
11-27-2018, 06:45 PM | #2 |
Drives: 2013 1le 2ss rs black Join Date: Jun 2016
How thick are they? Looks ok to me.
Sent from my iPhone using Tapatalk |
11-27-2018, 07:03 PM | #3 |
Who Needs to KNOW?
Check minimum thickness at center of the wear spot - not at the edge.
If within in, send it, if not, replace pads and rotors.
ing for grip.
11-27-2018, 07:21 PM | #4 |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
Those actually look pretty good, modest heat checking, as long as they are > minimum thickness, good to go!
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
11-27-2018, 07:48 PM | #5 |
I was set for 4 track days in a row, first 3 went great, then the 4th day was getting some bad vibrations under braking, so was that just pad material build up or something? Stock pads are down to about 50%
11-27-2018, 09:03 PM | #6 |
they look fine for now...mine were way worse after about 12 track days.
11-28-2018, 06:41 AM | #7 |
Drives: 1LE Join Date: Sep 2017
I tell you what...."yeah you need new ones!" Oh and by the way ship ur old ones to my address AND i WILL DISPOSE OF THEM! lolol....THEY ARE FINE..gotta get a pic of mine
11-28-2018, 06:50 AM | #8 |
Drives: ISO ss 1le Join Date: May 2018
Yeah you're fine. The vibrations are probably pad deposits as warping rotors is very, very hard to do. Run an aggressive pad with cold brakes for a few days in a row on the street and it should take care of deposits.
11-28-2018, 05:05 PM | #9 |
Drives: ZL1 A10 Join Date: Dec 2017
My rides:
2017 Camaro ZL1 A10 2015 Jeep Grand Cherokee Diesel 2012 Audi S4 1992 Porsche America Roadster 1990 BMW 325Ic |
11-28-2018, 06:53 PM | #10 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I’d change pads at 50% since they also absorb/remove the heat. Pads are a heat conductor...
Rotors look fine, agree with measurements in the middle of the rotor but, I ck top, middle, and bottom to see how its wearing ... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-29-2018, 04:50 PM | #11 |
getting some bad vibrations under braking is the issue now
11-30-2018, 12:33 AM | #12 |
Drives: 2014 Porsche Cayman S Join Date: Nov 2018
I don't have a Camaro yet, lurking here, but years of experience on this question. You don't NEED new rotors (as other people say, assuming the dimensions are still OK) but I can promise you you'd enjoy the car more if you changed the rotors, given your vibration problems, which in my experience will be fixed by new rotors. Me, I'd replace them.
11-30-2018, 07:37 AM | #13 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Can't tell from the pictures whether I'd be able to catch a fingernail in any of those heat checks. That's at least a crude indication that they're starting to open up a bit.
I think especially if you're not trailering the car to the track, you need to err on the side of caution here. Norm
'19 WRX 6M (the family sedan . . . seriously) |
12-01-2018, 01:08 PM | #14 |
They measure right at 33mm with variations depending on where you measure (32 is the discard thickness). I don't think it's pad buildup. Plan is to see if these can be resurfaced depending on cost and per the service manual guidelines. If not I've got new ones ready to replace them. Thanks for your inputs
