11-10-2018, 06:23 PM | #1 |
Drives: 2016 Camaro 1SS, Jet Black, M6 Join Date: Sep 2018
M6 Fluid Change Question
I was just wondering from those of you that have changed the fluid in your SS M6(MM6) Transmissions. Did you only change what was in the transmission itself or did you flush the cooler too?
I changed the fluid a couple weeks ago to see if it would help with the 2nd gear crunchiness but have been reading now that with the cooler the capacity is higher. I just wondering since i used RP Syncromax what the remaining fluid in the cooler might do and if i should have flushed it as well? The RP seemed to have helped for a bit but i'm still getting the crunching even after the transmission has warmed up, not as bad but still there.
2016 Camaro 1SS | M6 | Jet Black | Roto-Fab Dry w/SND Tube Delete | AWE Touring Cat-Back Exhaust |
11-10-2018, 10:13 PM | #2 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
I just changed the fluid in the transmission.... put in the D4 redline synthetic fluid. It didn't change the way it performed at all.. Most on here will say it helped, was not my experience though ... The only way I found to prevent the grind was to move the shifter to neutral between 3rd and 4th then go to 2nd. it works seamlessly, and I've gotten used to shifting this way.
11-12-2018, 12:21 PM | #3 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
Just changed fluid for the first time yesterday. 1600 miles on car. Used RP Syncromax and did not flush cooler. I can definitely notice smoother shifting with less "notchiness". Never had any "crunchiness". That sounds like a trip to the dealer may be warranted.
11-12-2018, 04:55 PM | #4 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
I had a notchy time with my transmission as well. When you go to swap the fluid, run a couple qts of cheap ATF through the transmission to rinse it out a little. Worked like a charm for me. I ended up going with the ATF from amsoil.
Also, if your car was not perfectly level during your first fluid change, double check the fluid level.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
11-12-2018, 06:42 PM | #5 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I agree with the above comments...I would only add to make sure you do not overfill.
Use the the 1/8" mechanics wire or the 6oz trick. Don't fill until it runs out of the fill port and call it good.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-12-2018, 07:31 PM | #6 |
I'm fairly certain that i did not overfill it, will double check to be sure. I filled it until it just started to weep out the fill hole, then pulled out around 6oz or so. If it is overfilled can't be more than a couple ounces.
It was was doing the same thing shifting 1-2 and sometimes 2-3 before changing the fluid, that's why i changed it. It's better when its warmed up but still happens sometimes. I've been reading about what i think are similar quirks with this transmission. Also when you all say notchiness and i say crunchyness we are talking about the same thing. It more like a grinding through the shifter, but not a real gear grind(I know what that is). I hate to think its the syncros but that's what i'm starting to believe. I bought it used as a Certified Pre-owned back at the end of June, so no telling how the previous owner drove it. Should i change it back to the GM stuff before taking it in for warranty?
11-12-2018, 07:39 PM | #7 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Is royal purple the same color? How would they know what fluid you put in it. Dont tell them.
11-12-2018, 08:00 PM | #8 |
Nope it's purple hence Royal Purple.
11-12-2018, 09:01 PM | #9 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I only changed the fluid in the transmission (unbolted rear crossmember and supported trans).
As others have stated, the service manual stresses not to overfill the MM6. Here's a quote from the manual: "IMPORTANT: Transmission fluid level setting must be followed exactly as written or the transmission may be overfilled or under filled. For fluid recommendations, Refer to Adhesives, Fluids, Lubricants, and Sealers (MM6) Transmission fluid level MUST be 3.2 mm (1/8 inch) below (1) the fill plug. This can be done by one of the following methods: 1. Bend mechanics wire to 3.2 mm (1/8 inch) to check fluid level. Add or remove fluid as necessary. 2. Fill transmission until level with the bottom of the fill plug hole, then remove 240 ml (8 ounces) of fluid." See the attachment in this post called "manual trans flush.pdf": https://www.camaro6.com/forums/showthread.php?t=500494 I also referenced this thread when I did mine: https://www.camaro6.com/forums/showthread.php?t=492814
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
Thread Tools | |
