11-11-2018, 10:21 PM | #15 |
Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
Off topic: is there a list of all the changes/differences on the 2019 MyLink?
11-29-2018, 01:45 AM | #16 | |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
If the MyLink2.5 HMI's and radios are similar in computational architecture and specifications (CPU, memory, storage, etc) to the units running Infotainment3, then the software is technically backwards compatible. Ethernet for transmission is cheaper to deploy for the order of magnitude of greater components automakers are trying to stick onto the bus. Your cars are becoming their own IoT networks now with hundreds or modules wanting bus access. Fiber channel is superior for its' speed, bandwidth and diversity of channels; but its' costly. MOST can run on multiple transmission technologies, but they are ditching it for two reasons -- 1 is that they are building a bigger bus on ethernet for the cost savings to serve all these new systems being added and 2 is because MOST is no longer the walled garden it once was. Also, just going to call this now -- automakers are going to get so cheap that they are going to run aluminum core cabling instead of copper to save 500$/vehicle and the recalls from that mistake are going to make the Takata airbag scandal look like a bargain. Cladded aluminum wiring fails in even the most optimal of environments. A vehicle sitting out in the elements is far from ideal. |
11-29-2018, 05:27 AM | #17 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
You realize alot of houses are powered with aluminum cable,that are outside the house, and exposed to the elements? There is nothing wrong with aluminum except that you need more of it to conduct the same amount of power, aka bigger sized wire, because it has more resistance than copper.
12-02-2018, 03:25 AM | #18 | |
A CCA wire uses the copper coating for signaling and the aluminum core provides gauge for power transmission. It can do one or the other just fine, but sucks at doing both. Ever had a USB cable fail to charge and do data transfer at the same time between your phone and car or computer? That is why. The cable was made with CCA or aluminum instead of copper. Trying to run PoE devices over CCA triggers random faults as well. Monitoring long term stats between redundant interfaces on the same two pieces of network gear, one with copper and one with CCA, you'll notice the CCA interface logs jitter more often and has a higher worst case score historically. It's due to aluminum and CCA being more prone to interference. When aluminum is used for large power delivery, such as pole based utility power to your home, you'll find that the fuses on the pole mounted transformers blow more often during heavy ionization if large isolators on the wire and shielding on the fuses are not used. But when a utility is being cheap, they would rather not deploy that extra expense everywhere and just roll a truck stocked with lower cost fuses to run out there when it does happen. If only utilities were required to provide the same SLA to all customers. |
12-02-2018, 08:02 AM | #19 |
Using aluminum to power a house is perfectly fine. It doesn't hurt the life of the transformer, if it did, it wouldn't be worth doing because of all the costs or repairing transformers, sending iu tr emergency teams, etc. ALL wire needs to be protected by a jacket or it oxidizes and corrodes, therefore not conducting as much electricity. They also use aluminum for ground mounted transformers as well, and those things arent cheap. Copper is king you are fight, but cars aren't houses, they arent meant to last nearly as long. Copper wire life underground is 40 years, aluminum is around 30, and that's underground, with moisture constantly all around it, but since it is in a jacket it doesn't matter. Now wire that's above ground, exposed to open air and possibly a little moisture is gonna last just as long if not much longer. The open free air helps reduce the temperature in the wires, which cause more electricity to flow. As Long as their isnt a ton of higher voltage running next to them, google calls it the proximity effect but I've always just called it leaching. To be fair, I dont know much about the analog smaller devices, but I'm learning schematics as I'm starting to work on well pumps and vfd drives drives. Completely un related I know, but look into vfd drives (variable frequency drive), it's the way of the future for almost everything electrically driven by a motor. You seem like you might be interested in stuff like that. I've been doing electrical for 17 years now and love talking about it, hah.
10-23-2021, 11:19 AM | #20 |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Nov 2018
You can you have to change the module out
Instagram- ants2sv4
10-23-2021, 05:50 PM | #21 | |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
https://www.tesla.com/support/infotainment https://youtu.be/3aPd_VMO-m4 Last edited by Plasar; 10-23-2021 at 06:06 PM. |
10-23-2021, 07:49 PM | #22 | |
Tags |
dash, digital, mylink update, refresh 2019, software |
