Old 11-02-2018, 06:15 AM   #1
Jayd0002
Jayd0002's Avatar
HELP! High RPM Shift Problems TR6060
Hi Everyone- I could really use all of your input- Ive got a 2017 Camaro SS with the TR6060 (6spd manual) I am having big problems when trying to shift from 3rd to 4th, or 4th to 5th but ONLY when RPM's are ABOVE (about) 5000 RPM. It feels like Im just locked out, so I have to give it about a second for the RPM's to drop by a couple hundred, and then i can continue to upshift. The car shifts perfectly in ALL other situations. So far the only mods I have are a GM performance cold air intake. Custom exhaust including headers. I have a SCT BDX tuner- im using a remote tune- I spoke with person who wrote the tune- he said he didnt mess with any transmission settings. The car has NEVER been tracked, Never seen any kind of crazy burnout. Ive lit it up a couple times but very quick. I dont beat the shit out of it. I have good habits with the clutch- dont grind gears. Dont miss shifts. I dont ride the clutch. Car only has 12,000 miles. I dont know when this problem started because im not always driving really fast and aggressive like this. I do know that months ago, it did NOT have this issue. Its still on its original trans fluid. I did buy RP Synchromax but have NOT put it in yet. I am a Ford technician- work at a Ford dealer. I have limited transmission work experience though. I havent brought it to the dealer yet. Id like to fix myself first, IF possible ----What could be issue?? Fixes???
Jayd0002 is offline   Reply With Quote
Old 11-02-2018, 12:19 PM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Mine does this from first to second only, but higher rpms. Same thing about hesitating to shift, works perfectly that way. I have redline atf which seemed to help for a little bit, but it's back again.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 11-06-2018, 10:40 AM   #3
corsa636
Drives: Ford Focus
RPproductions reported the same issue in one of his youtube Videos..
(The one where he had been on the drag strip, if I remember right)
corsa636 is offline   Reply With Quote
Old 11-08-2018, 11:02 PM   #4
TheStig1164
Drives: 2018 Camaro 2SS 1LE
Same here, went to the dragstrip last night, had 2 runs where I couldn't get it in 4th. Ran a 12.71 on my last run, missing 4th got me eliminated...
2007 Silverado 5.3: Texas Speed longtube headers catless, Ported throttle body, K&N CAI, Flowmaster super 10 exhaust, super slow.
1997 Camaro SS 6-spd 30th anniversary edition: Flowmaster exhaust, still slow.
2018 Camaro 2SS 1LE: not that slow
TheStig1164 is offline   Reply With Quote
Old 12-09-2018, 07:49 AM   #5
Jayd0002
Jayd0002's Avatar
STIG- Have you come up with any explanations with your problem at the strip?
Old 12-30-2018, 11:41 PM   #6
Calcanuck
Calcanuck's Avatar
Drives: 2017 Hyper Blue 2SS
Same here from 2-3rd at high RPMs. Feels like you hit a wall when trying to get 3rd. Does not do it all the time. For me only happens at the track, I would say once or twice during a track day.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
Calcanuck is offline   Reply With Quote
Old 12-31-2018, 07:57 AM   #7
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
with your tune did they raise the rev limiter?
i see its been a few weeks since this post was made. This was happening to me when i had a non experienced tuner tune my car. Put your rev limiter back to stock and you'll be just fine. I have videos showing what happens, might even have it on my youtube channel.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 01-01-2019, 06:22 PM   #8
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Bleed any air that may have found its way into the clutch system since its shared with the brakes, and trans fluid is my recommendation.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
