09-20-2017, 05:39 PM | #1 |
Drives: 2016 2ss Join Date: Jan 2017
Mighty mouse catch can
I got a mighty mouse catch can wild kit 800hp. Unsure of the correct way to install, or even if my fittings are installed where needed. I am procharged. The catch can port with the sight glass below it should go to where? I know larger line to oil cap, and snaller to the intake pcv port, then cap the valley port.
09-20-2017, 06:58 PM | #2 |
Drives: 2014 Stingray, 2017 Cadillac XT5 Join Date: Jun 2017
David will be happy to help you. Didn't you get instructions?
09-20-2017, 07:50 PM | #3 |
Ive actually talked to david already. Ive told him what my setup is, and hes told me what to do, but every other can ive seen seems to be hooked up a different way than I was going to, and david said theres been very few with a procharged camaro thats running the can yet. Maybe mines different, heck idk. Was hoping someone else had one on their procharger setup and could gekp ease my mind.
09-20-2017, 09:58 PM | #4 | |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
09-21-2017, 06:28 AM | #5 |
Mine is the wild version that I believe was 800hp compatable. The bigger fitting(one that the 1/2 line comes out of and goes to the oil cap) directly over the sight glass is completly open so i can flow air both ways, the smaller fitting to the right of the sight glass(one that goes to the pcv intake port) I can suck air out of the can(kind of restricted) but cant blow into the can at all. I havnt tried to do anything with any kind of high pressure compressor or anything, this is just me using my good old lungs. Lol.
09-21-2017, 09:16 AM | #6 | |
Under normal intake vacuum, it's pulling crankcase dirty air through the larger fitting. Anything attached to the other side of that catch can (Large fitting) is getting pulled into the can and trapped. During BOOST. That smaller fitting being a 1 way will not allow boosted pressure to enter the can. While under boost the vacuum that once was drawing dirty air into the can is temporarily disabled but any pressure from the crankcase can evacuate through the vented filter on top of the can through anything connected to that larger fitting (flow air both ways). The machined fitting holes are universal. You can have whichever fitting you want over the sight glass. I.E Clean side or Larger dirty side. It's up to you how you want it oriented. Hope that makes sense. If I misunderstood anything you were asking don't hesitate to ask.
09-21-2017, 12:49 PM | #7 |
I guess this is what i needed! I just couldnt wrap my head around how the flow actually happens and. Ow that i know, it all makes sense. And just to verify, its best to cap off the valley port woth the cap and clamp, correct?
09-21-2017, 04:50 PM | #8 |
yep. Since you are already evacuating crankcase vapors via the valve cover adapter, the valley port would be redundant.
09-21-2017, 05:51 PM | #9 |
Thank you!!
09-28-2017, 09:36 PM | #10 |
Ok, so my tuner has been working on my car the last couple days. Said he has it all dialed in,but between 5400-5800 rpm he is seeing a slight "miss" and afr changes slightly approx .20 diff, and comes back if he goes past or allows it to drop lower than the rpm listed above. Any recommendations on things to check? Boost holds steady, doesnt rocket up or fall off when it happens etc. He said he is clueless as to why its doing it, only thing he is contributing it to is the fact that its the first rubber/silicone charge kit hes done, usually does a stainless/aluminum setup. Hes very very knowledgable with F.I, been tuning 15+ years but is stumped.
09-29-2017, 01:29 PM | #11 | |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
09-29-2017, 03:11 PM | #12 | |
you got it.
03-17-2018, 04:54 PM | #13 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
I just installed my MMS Wild Catch Can and had to switch the fittings and rotate the inside of the can around so both fittings would face driver's side of vehicle.
Also, wanted to check since I'm Procharged, I have a vacuum box that connected the blow off valve and the valley and PCV ports. Basically a vacuum junction box. I am assuming since you cap the PCV port that the valley port flows through the vacuum box and instead of connecting to the PCV port, it now connects directly to the clean side of the catch can. Does that sound right?
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
03-17-2018, 05:44 PM | #14 |
Hey sent you a PM. Just to clear up any misunderstandings with the terminology. Just wanted to say that the way I understand it. the Valley Port is the lower one with the PCV built in and where the dirty crankcase air comes from. The upper connection near the throttlebody is the clean side intake port.
So cap off the lower valley port. No longer needed. Connect the upper intake port to the that vacuum junction box and from there to the clean side of the catch can. (the one with the PCV built into the can) You already know the dirty side of the can connects to the oil fill cap adapter
