08-23-2016, 07:19 PM | #15 |
Drives: 16 2SS Join Date: Jul 2016
Sorry for the delayed post guys but I have things wired up and am overall very pleased with the results!!! Here is a pic of how I wired things up and once I have everything exactly the way I want it, I will work on cleaning up the wired spaghetti mess!!
Here are the wires from the factory Bose amp I used to feed the inputs of the Fix 82. For the mids and highs, I used the rear speaker left and right. These are the speakers located behind the driver and passenger seats. Those wires are located on the Bose amp X2 connector which is the 16 pin Green connector. The wire colors for the rear speakers on the X2 connector are: Left rear + (Green) pin #7 left rear - (Green/Black) pin #15 Right rear + (White) pin #6 Right rear - (Blue/Black) pin #14 Those 4 wires are used to feed the input of channels 1 & 2 on the Fix 82. Now for the lows, I used the rear subwoofer left and right. These speakers are split up between 2 separate connectors on the factory Bose amp. The left rear subwoofer is on the X1 connector (Black 8 pin connector located to the right of the green X2 16 pin connector) and the right rear subwoofer is located on the X2 (green connector) Left rear subwoofer + (X1 connector Blue/Grey) pin #1 Left rear subwoofer - (X1 connector Green/Black) pin #5 Right rear subwoofer + (X2 connector Green/Violet) pin #16 Right rear subwoofer - (X2 connector Grey/Black) pin #8 These 4 wires are used to feed the inputs of channels 7 & 8 on the Fix 82 which channels 7 & 8 are specific for subwoofer frequencies on the Fix 82 X1 connector pin out (Got this diagram from another member on forum) 8 pin Black connector X2 connector pin out (Got this diagram from another member on forum) 16 pin Green connector |
08-23-2016, 07:35 PM | #16 |
Now for my remote 12v turn on, I did find a switched fuse that is controlled by the ignition. That is fuse #33 (labeled Wless Chrgr). This is located in the rear fuse box in the trunk just to the left of the battery.
F33 |
08-23-2016, 07:45 PM | #17 |
I got extremely lucky!! If the sub box was 1/8 of an inch bigger it would have not fit in the opening of the trunk!!!
08-23-2016, 07:46 PM | #18 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
Looks good...curious as to why you didn't connect door speaker and dash tweeters to inputs 3_4_5_6? I would be worried that the way the bose amp is crossedover and equalized that you may be missing out on certain frequenc ranges...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
08-23-2016, 08:01 PM | #19 | |
That is a very good point and I do plan on trying several different things to see if I can notice any difference and what you mentioned is exactly something I plan on doing to test. This is just my first attempt at hooking things up and if any other change makes it sounder better than it does now..... then that will just be icing on the cake!!! Another thing I am going to try to do is clip the ANC microphone wires and see what if any changes that makes. |
08-24-2016, 08:39 AM | #20 |
Looking to add the same sub you did. Would the FiX-82 add any value if all I am running is a sub? Its been a long while since I've done any car stereo and from the look of things its not just adding aftermarket headunit and running wires to subs anymore.
Edit: After doing some reading it looks like I only need to get some speaker wire to rca adapters and tap into the left and right sub. Picking up the JL Slash V3 600/1 for my amp so I shouldnt need a remote wire. Also which wires on the X3 adapter are the microphone wires. Looking to cut those too.
Adrenaline Red
20" 5 Spoke Black Black Side Spear Dual Mode Exhaust MRC Splash Guards 1G1FG1R74G0124089 Last edited by lDejavul; 08-24-2016 at 11:50 AM. |
08-24-2016, 12:36 PM | #21 | |
I don't have the microphone wire diagram here at work but I can get that for you when I get home. |
08-24-2016, 10:04 PM | #22 | |
The mounting adaptors I made are not the prettiest but they get the job done plus you cant see them mounted anyways. Picture of the tweeters and one of the mounting adaptors Picture of the stock Bose Driver side tweeter Picture of the new JL Audio Passenger side tweeter And here is a pic of the center speaker. Just took a pic of it since the dash was apart. Last edited by matt713; 08-24-2016 at 10:20 PM. |
08-24-2016, 10:10 PM | #23 |
How hard is it to get the dash apart?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
08-24-2016, 10:48 PM | #24 | |
The passenger side is the same as drivers side except once you remove the 7mm screw you will remove the top part of the dash that covers the defrost vents and where the center speaker is mounted. You will need to disconnect the automatic headlight sensor plug if your car has that feature (not sure if that's standard on all models) that's it, you can now get to the tweeters. The second thing that sucked was on the drivers side tweeter, removing the mounting screw to the right (if sitting in the car facing out the windshield) is a pain to get to because it is so close to the windshield there is very little clearance. Wish I had taken more pictures but I was in a rush to get them installed and slacked in taking pictures. Matt |
08-25-2016, 07:30 AM | #25 |
How did you connect the tweeters? crossed over from aftermarket amped door speaker?
08-25-2016, 07:55 AM | #26 |
Drives: camaro Join Date: May 2013
So in order to remove center speaker grill, right side speaker grill has to come off??
Hyperblue/JetBlack |
08-25-2016, 08:14 AM | #27 |
08-25-2016, 08:20 AM | #28 |
