Old 10-03-2023, 07:09 AM   #1
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Seeking info about our differentials
I read about the 2.77 to 3.27 swap. Does anyone know where I can read more about what type of diff are cars are equip? I'm used to the old Dana 36 & Dana 44 setups.
Understandably these cars are still a "little" new, and seeing how money talks. Do other companies such as Richmond make different ratios?
Thanks!
NiickySaz is offline   Reply With Quote
Old 10-03-2023, 08:14 AM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
To my knowledge, there are no aftermarket rear gear sets available for our cars. To change the gear ratio you will need to change out the diff. Even that is complicated to get the car's computers to play along with a swapped-out diff.
476 rwhp/440 rwtq (sold)
Old 10-03-2023, 08:40 AM   #3
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
There are no aftermarket solutions for changing the gear ratio's. There is one company that makes a 9 inch conversion for about $5000. And I don't think you can just swap rear diff's with another with a different gear ratio becsuse of the TCM, BCM and other computer stuff. My understanding is there are welded parts in the carrier that con not be serviced and or replaced. I can tell you how much a new rear diff and drivers side axel costs to be replaced Good luck.
dmcmahan60 is offline   Reply With Quote
Old 10-03-2023, 11:23 AM   #4
NiickySaz
NiickySaz's Avatar
I too read about the welded in parts, strange.
Is there a specific name for the type of differentials the gen6 has? Or better yet(still trying to dig up info) a direct link to explain about the differential? Thanks!
Old 10-03-2023, 01:11 PM   #5
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
For OEM information I made this thread:
https://www.camaro6.com/forums/showthread.php?t=584316
You can’t swap a eLSD diff unless you get custom programming and custom harness, otherwise all you really have to do to swap a diff is change the value in HPTuners after changing the diff
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 10-03-2023, 01:11 PM   #6
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
I kept running into dead ends trying to find any information on them. Even my local rear end guy that has been building differentials for the past 40 years did not want to touch it. I too would like to learn about them but my only option was to buy new and have it replaced. The Chevy tech kept telling me the carrier is welded or non serviceable.
Old 10-03-2023, 01:18 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I think one of the members in Europe did a swap not long ago
Old 10-03-2023, 01:22 PM   #8
ctrlz
Some great photos and info here. pretty over-the-top by my standards, but great stuff:
https://www.camaro6.com/forums/showthread.php?t=547186
Old 10-03-2023, 02:16 PM   #9
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
wow, thanks for the information! This would explain the excessive left to right play in the drivers axel I had when it failed. Could still drive the car but the noise and gear noise i had when you left off the throttle was horrendous! Thank you for finding this thread!
Old 10-03-2023, 02:32 PM   #10
L78toLT1
L78toLT1's Avatar
[QUOTE=Bumbleboy92;11365412]For OEM information I made this thread:
Has anyone actually done this, I wonder? If it’s as simple as tweaking a few tables in HPTuners and adding a harness that doesn't require a near total disassembly of the car, I may consider it.
Baby Blue
Old 10-03-2023, 03:27 PM   #11
NiickySaz
NiickySaz's Avatar
This is some good stuff, thanks!!!!!!
Old 10-03-2023, 03:31 PM   #12
NiickySaz
NiickySaz's Avatar
Looks like buying a different diff is the way to go an play around from there. Possibly taking pictures an sending them to a specialist who knows more about these than me lol
Old 10-03-2023, 09:13 PM   #13
fattyz28
fattyz28's Avatar
Drives: 20 2SS 1LE
A eLSD swap has been done in a ZL1. He went from the 3:73 in his 6 speed car to the automatic 2:85 rear end. I’m pretty sure it was a remove and replace install. After he used hp tuner to adjust the rear gear ratio to correct the speedometer. Not sure if that was everything to correct it, but it can and has been done.
https://youtube.com/watch?v=gJa3huV5...BujOqDfINeU5ai
The name of his channel is The Drive Inside.
fattyz28 is offline   Reply With Quote
Old 10-03-2023, 10:33 PM   #14
Bumbleboy92
Long hauler
There’s been a few guys with automatic v6’s that swapped their non-LSD 2.77 to the 3.27 LSD. They needed the corresponding axles and changed the HPTuners value and were good to go. Hyperhawk is one of them and even did an install video
There’s Hadies in the forums building a twin-turbo supercharged v6 and has an entire ZL1 rear end he used with custom programming/harness for control: https://www.camaro6.com/forums/showthread.php?t=613779
Originally Posted by Hadies View Post
Drivetrain and Brakes
ZL1 front and rear brakes, I actually installed the entire rear cradle from a ZL1 and made a customer harness for the controls and GMLAN BUS. Unlocked transmission controller from HP and RX stall converter from Tracy Lewis performance.
2016 1LT v6
- Totaled
Happiness: Infinite
