Old 10-05-2017, 02:39 PM   #1
ScottMHoffman
Drives: 2017 Camaro SS 1LE
Engine Protection Warning
At the track on a hard down hill left in third gear I would get the engine protection warning, power would be reduce and revs limited to 5500. Was not a problem in 4th gear.
I put an extra quart of oil in and it went away most of the time.
Is this an oil starvation issue? Is the solution to make sure the motor always has a quart more oil at the track?
ScottMHoffman is offline   Reply With Quote
Old 10-05-2017, 03:07 PM   #2
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
It is in the high performance supplement to run 11 quarts for track use.
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 10-05-2017, 03:10 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by ScottMHoffman View Post
... Is the solution to make sure the motor always has a quart more oil at the track?
Absolutely not, but it's a great way to foam the oil and make it go ka-blamo while simultaneously getting your warranty voided.
10 quarts w/filter change. Don't play crew chief.
You didn't mention anything about coolant or oil temps. Have the datalog from your PDR? Is this repeatable, or just a one-time deal?
Old 10-05-2017, 03:11 PM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
No, it doesn't. It only says to add 1 quart if you have the V-6, and then drain it immediately for street driving.
Old 10-05-2017, 03:26 PM   #5
ScottMHoffman
it was repeatable but not every time. the harder I ran through the turns the more likely to happen. VIR hogpen exist of turn 17 on to the front straigth
Old 10-05-2017, 05:21 PM   #6
TrackClub
TrackClub's Avatar
Check you wire harness and ensure A/C belt doesn't rub against it. This was a fairly common issue on some cars. And as Ryephile stated, do NOT run extra oil unless it is a V6...I have zero oil starvation issues at Mosport, which has high speed, high G left and right hand corners. So likely something else is causing your issue.
Old 10-06-2017, 08:11 AM   #7
Gen5er
Mack da M1SS1LE
Gen5er's Avatar
Drives: 2017 Summit White 1SS 1LE
Man oh man
I love this forum. You guys rock when it comes to getting things done the right way. Nice info and "bad" info debunking.
Carry on and hammer down.
The "G" SEEKING M1SS1LE
Gen5er is offline   Reply With Quote
Old 10-06-2017, 12:32 PM   #8
DC2NERD
Drives: 17 SS 1LE and 95 Integra Track Rat
What kind of lap times were you running? My fastest at VIR is a 2:08.7, usually lap in the 2:11 range when I have open track but not pushing hard and I've never had this issue at VIR.
I'd guess its probably the wiring harness issue, I've never experienced fuel starve or oil starve at VIR and I've run with the fuel light on at the end of a session.
DC2NERD is offline   Reply With Quote
Old 10-06-2017, 01:44 PM   #9
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
What the PDR can do datalogs? How?
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 10-06-2017, 01:52 PM   #10
DC2NERD
Download the cosworth toolbox that is used with the PDR. Open the file in cosworth toolbox and you'll get lots of data.
Old 10-06-2017, 02:36 PM   #11
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Pull your dipsticks after a run, see if it's foamy or liquid.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
