Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 08-30-2017, 04:55 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Stainless Steel Braided Armor Camaro Brake Lines Upgrade
Whats up my fellow 5th Gen SS's?!? Ready to upgrade those old and boring brake lines and add a little "POP" to your chassis? We have just that, IN STOCK and available in red, black, or blue. Upgrade your factory rubber brake lines to these Performance Brake lines from Phastek Performance.
Fits 2010-2015 Camaro SS models with factory Brembo brakes (Set of 4, Front & Rear)
  • These lines are rated in excess of 6000psi where the factory rubber brake lines are rated for 1200psi.
  • End fitting construction - High-quality steel fittings, corrosion-resistant
    with DOT-compliant collar to protect fitting-to-hose junction.
  • DOT compliance - MVSS-106 certified
  • Mounting Attachments- Rubber-grommeted steel mounts that bolt into the factory locations.
  • Protection - Stainless steel braided armor is extremely resistant to impact from rocks and other road debris as well as rubbing wear from suspension components.
  • Lifespan - Essentially lifetime
  • Function - Greater pressure capability means less expansion under pressure, which results in a firmer pedal, better pedal modulation and control, and insignificant change due to elevated temperature levels from track or race use.
CALL CLICK PM EMAIL or online 24/7 at phastekperformance.com
Sales@Phastek is offline   Reply With Quote
Old 09-12-2017, 03:39 PM   #2
Sales@Phastek
Drives: 2016 1SS
CALL CLICK PM EMAIL or ONLINE 24/7 at PHASTEKPERFORMANCE.COM
Let me know if I can help
gabe
Old 09-20-2017, 10:39 AM   #3
15cammedSS
15cammedSS's Avatar
Drives: 2015 2SS....white
Any feed back on these brake lines?
2015 Summit White 2SS/RS with NPP.... Roto-Fab intake....Phastek lowering springs....BMR strut brace....custom cut blower cam and tune by Matt Sorian.....@MSTuning...BTR valve train....stainless power longtubes with HF cats....Phastek supplied
15cammedSS is offline   Reply With Quote
Old 02-10-2018, 03:05 PM   #4
Cheetoh
Drives: 2011 Callaway SC572, 2000 Firehawk
Are These Stainless Steel? If not, How do they compare with Stainless?
2011 Callaway Camaro, 572 H.P
Cheetoh is offline   Reply With Quote
Old 02-14-2018, 04:02 PM   #5
Sales@Phastek
Drives: 2016 1SS
Sorry for such a late response but yes they are Stainless Steel lines.
5th gen, brake lines, performance, phastek, stainless lines
