Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 12-26-2012, 05:34 PM   #1
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
TORQ Front Tow Hook Install DIY with Pics
I wanted to share some pictures and installation info on the TORQ front tow hook. Next season I am going to be doing some road course racing and my local track requires a front tow hook. The overall installation is easy and it looks great when done.
The first step is to support the front end and remove the wheels.
Next is to remove the inner wheel liners. There are several plastic retaining clips and some screws that will require a Torx 20 bit. With these removed the liners will come out allowing access to the other bolts and screws holding the facia to the front fenders. Also the front lamp harness unplugs near the right fog lamp.
With the facia removed the holes to mount the hook are drilled. The hook can be mounted in several positions. I chose to have it come through the left side of the grille. I also aligned it so I did not have to cut or modify the grille.
Using the supplied hardware the bolt can be secured to the front bumper brace. Then the facia can be reinstalled.
Overall it is a very easy install and with the hook installed you will be compliant for sanctioned events.
LSX Camaro is offline   Reply With Quote
Old 01-20-2015, 12:40 PM   #2
aztc4life
Vic Corral
aztc4life's Avatar
Drives: Camaro 2011 SS/RS L99
Whats the measurement distance from the left side of the front bumper brace to the hook??
aztc4life is offline   Reply With Quote
Old 08-21-2018, 06:08 AM   #3
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
No help from this one. I have the ADDON One with the swing down hook-up.
BLU DUCE is offline   Reply With Quote
Old 08-21-2018, 08:12 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Best thing to do is measure from center of crash bar and center of grill to desired opening of grill slot. Then do your math of the bracket an transfer measurements to your crash bar.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
