11-23-2020, 10:38 AM | #1 |
Drives: 2018 ZL1 Join Date: Apr 2017
MRR rims
Quick question, for anyone who's had the MRR MO17s, what size do you guy recommend running for a good look. I think the rims on the 1LE are 20s and was wanting that size. Any recommended sites you guys would use for ordering them. Im going to be doing a ZL1 1LE swap later, but for now just wanted a front splitter and side skirts and the MRR MO17 rims.
11-23-2020, 10:55 AM | #2 | |
Drives: 2017 50th anniversary edition v6 A8 Join Date: Mar 2018
11-23-2020, 11:56 AM | #3 |
As kpgreenwell says, get the 20x10 front and 20x11 rear, that is, standard 1LE sizes (front offset will be slightly different, though). This is exactly what I have, see my avatar.
11-23-2020, 03:17 PM | #4 |
Drives: 2016 Camaro SS Join Date: Oct 2020
I'm planning on buying the same wheels. 10"/11"
This is just my opinion on tires - if you plan on lowering the car, go with 285/30 and 305/30 tires. If you don't plan on lowering, I'd go with 275/35 and 295/35. I'm not planning on lowering, so I'm going with the 275/35 and 295/35. The 285/30 leaves a pretty big gap up front if you don't lower your car. |
11-23-2020, 03:42 PM | #5 |
Most of the guys I've seen with these wheels are running 20x10 front with +23 and the rears are 20x11 +43 which if I'm not mistaken are the stock offsets on the 1LE's and ZL1's. I run the MRR M228's in those sizes on my 5th gen with 275/35 front and 315/35 rear and am lowered 1.25 on Pfadt's..
11-23-2020, 03:50 PM | #6 | |
11-24-2020, 06:44 AM | #7 |
Drives: 2023 Sharkskin Metallic 1LE Join Date: Mar 2018
I have a set of the MRR wheels you are looking for. Check out my post in the classified section.
11-24-2020, 07:01 AM | #8 |
I had a set of the the M017 sized 20x10 ET23 and 20x11 ET43. Used the Supercar 3 tires in 285/30 and 305/30 like the 1LE. These wheels, being an inch and a half wider than stock, fill up the stock SS fenders quite a bit, so I also added the GM accessory splash guards because of that. Illustration below:
11-24-2020, 01:48 PM | #9 | |
To me these are the best looking wheels on a Camaro. On a red Camaro especially!! ^
11-24-2020, 02:54 PM | #10 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Guess I'm the odd duck.
I went with the 20x10 all around. Still wider than stock on the front end, and the aggressive offsets give the appearance of wider tires out back since they stick out further than stock also. Looks fantastic. I have no real need for wider rears, and this allows me to rotate as well if I want.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
11-24-2020, 07:38 PM | #11 | |
Drives: 2024 2SS Camaro Nitro Yellow Met. Join Date: May 2020
I'm running MRR M017, Front: 20x10 +23 off set, 275/35/20, w/BMR lowering springs, Rear: 20x11 +43 offset w/ 5mm wheel spacers, 315/35/20, I have a 1 finger gap from the top of tires front and rear to the fender lip, perfect gap, absolutely no rubbing whatsoever on front and rear, If you decide to go bigger than 305 i highly recommend you relocate the harness in your left rear wheel well so the tire doesn't rub through liner and damage your harness, I attached 2 pic's, front and rear, showing gap of tires to fender lip, you'll have to rotate the pic's so you can see them in the correct orientation. |
11-24-2020, 08:03 PM | #12 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
Anyone running BFGs on these?
'17 2SS ■ HBM ■ Kalahari ■ NPP ■ Glowtie ■ GMP CAI ■ 1LE wing ■ 1LE Splitter ■ Wickerbill ■ IKON diffuser ■ ZL1 sideskirts ■ SEMA Grill ■ Redline Badges ■ |
11-25-2020, 10:02 PM | #13 |
hi, anyone running all seasons on stock 1LE rims? almost impossible to find all season tires in stock 1LE sizes. let’s share what size / brand all season tires you are running. Trying to get some idea.
Thanks Have a Great Holiday! |
11-26-2020, 07:10 AM | #14 | |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
For what it's worth I got the MMR Z28 rims in black for my A/S tires, they are surprisingly good for off shore knock off, you will need an additional set of lug nuts as the stock ones won't fit. |
Tags |
2016 2ss, 6gen camaro, mrr 1le wheels |
Thread Tools | |
