10-17-2020, 05:47 AM | #1 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Gains from just a tune?
Worth just doing on a tune on the LT1 with no other mods?
I saw gains around 30hp and lb ft with my 06 C6 with the LS2 with AR headers and dyno tune and around 37hp with the 2013 LS3 C6 with Kooks headers and tune. My new 2021 LT1 runs nite and day better than my 2019 C7 did stock tune vs stock tune. |
10-17-2020, 06:29 AM | #2 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
A tune might get a little more, but in reality, the real gains come from increasing air flow through the engine. I would wait until you get the headers then do the tune. On a side note, there appears to be a TSB about some engines that may or may not have gotten a bad batch of valve springs. That said, I would wait about a year before even thinking about touching the engine. Unless you just want to go full on mod and cam it with AFM delete, or maybe just get in front of it and change the springs now. |
10-17-2020, 07:36 AM | #3 | |
Looking for around 50hp in gains to start off. I figure just a tune may get ya 12 to 15hp. Not sure what gains headers and tune do on the LT1 alone. I know headers, tune and cam should get me there. I gotta worry about tires first as they break loose like a silly goose as it is. |
10-17-2020, 07:48 AM | #4 |
Drives: 2019 ZL-1 Join Date: Feb 2009
The LT1 tune from the factory is actually pretty dam good. Your LT1 has OE shorty tri Y headers from the factory. If your ging to tune include an E85 tune (which reguires an E85 fuel sensor on the engine)
Search is your friend.
2012 Yukon XL Denali w/ 6.2 AWD |
10-17-2020, 07:52 AM | #5 |
maybe 15 hp
'20 ZL1 1LE A10,
10-17-2020, 08:03 AM | #6 |
I agree with MrChris to leave it alone for a while because of the bad valve spring issue. Yours might be affected or might not so the warranty would be used then for replacement of the springs. The LS engine is a lot different than the LT engines in my opinion and seems that the LS engines were more responsive to mods than the LTs are and the aftermarket supports the LS engines more too. If you plan to mod your LT1 I would get a set of wider wheels and tires and possibly bigger rear brakes and if it was me I would install a Edelbrock E force or Magnacharger S/C and call it done! I would think having a supercharged LT1 would be cool and very different and would be cost effective for adding the hp you are wanting.
10-17-2020, 08:12 AM | #7 |
The batch of bad valve springs was engines from july-2020 to Sept 2020.
Not all v8's have these. I surmise a batch of improperly heat treated springs from a supplier got into the supply chain.
10-17-2020, 08:15 AM | #8 | |
Maybe just throw a S/C on it and tune and call it a day without doing long tubes would be ok. Not looking for monster gains. 550hp would be plenty with my local traffic. |
10-17-2020, 08:16 AM | #9 |
10-17-2020, 08:24 AM | #10 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
This right here is why I said just get a ZL1.
10-17-2020, 08:48 AM | #11 |
10-17-2020, 08:58 AM | #12 |
Both of those superchargers would net you around 150 hp and are offered as complete kits including a canned tune which would be fine for your LT1 since you are wanting about 600 hp.👍
10-17-2020, 09:56 AM | #13 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
10-17-2020, 10:31 AM | #14 | |
Now you can find used ZL1's for a much lower price. I recently seen a 2017 Hyperblue A10 1 owner 4k miles sell for 49k locally. Had those kind of prices been around 3yrs ago I would of just spent the extra and went to the ZL1. I don't care about warranty. If I break it I can afford to fix it. That being said, a tune only isn't really worth it on a LT1. You might see 9-10whp gain. If it's a auto then you will pick up a bit from a trans tune but that only applies to 2016-2019 cars because they 2020+ Automatic transmissions can not be tuned.
2016 NFG 1SS A8
