01-13-2019, 03:47 PM | #1 |
Drives: 2017 Camaro 1le 2016 Camaro Black 6 Join Date: Jul 2018
1LE V6 What suspension do I actually have?
Search function doesn't work for me so here goes.
I know it is supposed to have the Fe3 suspension now. So does this mean I'm basically upgrading a SS model suspension when I buy parts. Just trying to get a base point to know what parts I need to be looking at. Or sell and buy a V8 1le. However I didn't want magnetic ride. Any help will be appreciated. |
01-13-2019, 04:00 PM | #2 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Why do you want to change it? Have you tracked it stock? 6th gen ss 1le all have mag ride.
2017 1LE Hyper Blue
01-13-2019, 04:34 PM | #3 | |
Drives: 2017 SS 1LE Join Date: Mar 2016
IG: @NC_M1SS1LE
01-14-2019, 01:44 AM | #4 |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
Is damper tuning a little different, or are part #s for shocks and struts the same for the V6 1LE as the base SS?
01-14-2019, 09:01 AM | #5 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
01-14-2019, 12:30 PM | #6 |
Thank you for all the responses.
I have not had it on the track yet. However, I have had it in some spirited driving. Hwy 125, 248, and 160 in southern Missouri. Great roads by the way it does well. But could be a lot better in my opinion. Also I drive 800 + miles one way to work in west Texas. At higher speeds it does begin to feel soft, wash out like spring dampening is too soft. I will check out the thread on magnetic ride. I remember about 20 years ago hearing about it on the new Cadillac. Thanks again for responding. |
01-16-2019, 10:01 AM | #7 | ||
Mike
Drives: 2018 1SS 1LE Join Date: Nov 2014
01-16-2019, 11:46 AM | #8 |
Thank you Mike, I'll check it out.
01-16-2019, 12:28 PM | #9 |
So after checking out the suspension thread.
My car has the fe2 front stabilizer with fe3 end links, different front cool springs. Probably a lower spring rate die to engine weight. Rear springs same as SS fe3. That's as far as I've gotten so far. |
10-27-2020, 11:52 AM | #10 |
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8 Join Date: May 2018
Check the end links on your front sway bar. If they're metal (very likely), you have a FE3 bar. If they're plastic, the bar is FE2.
10-29-2020, 03:25 PM | #11 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
Why do you not want magnetic ride?
Two points: 1. Replacement mag ride shocks are not as much as you think. 2. Computer controlled damping that has calibrations for all sorts of situations. |
10-29-2020, 06:58 PM | #12 |
Drives: none Join Date: Jan 2019
retrofitting Magride to a non- car is no trivial or inexpensive undertaking.
10-29-2020, 08:47 PM | #13 |
10-30-2020, 07:30 AM | #14 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I did the research once upon a time for when it's time to replace my suspension, and I believe the front spring is the same as on the fe2
