06-24-2019, 06:29 PM | #197 | |
SS Copbait R.I.
Drives: 2016 Camaro 2SS Join Date: Dec 2016
Ditto, I have been trying to avoid my spare bedroom to dig for my old Stock TB. I have a Katech and I am very tempted to have my stock reworked as well. lol |
06-24-2019, 07:14 PM | #198 | |
Mobile/Embedded Architect
Drives: '16 2SS white convertible Join Date: Dec 2016
considering this bolts pattern is 1 ( ) 2 [] 3 ( ) 4 [ ]==== Remove bolts in the order of 4, 3, 2, 1 Bolt 4 has the tightest clearances. Removing bolt 4 last leads to issues. When the bolts are removed, rotate the TB 180 degrees to remove the cable connector. (insert how to remove connector without destroying connector) When re-installing the TB. Position the TB with a bolt pre-placed in position 4 with a socket attached that can be tightened with your fingers. Position 4 has tight clearances to the TB and is visually occluded. After Position 4 is partially threaded, partially thread bolts in position 1, 2, and 3. Tighten 4, 1, 2, 3 with a loose socket and your fingers until tight. Attach the socket to a ratchet and finish the tightning of each bolt in the order of 4, 1, 2, 3 Last edited by vidkidZ; 06-24-2019 at 08:59 PM. |
06-24-2019, 07:23 PM | #199 |
One more thing....
Throttle LAG begone!!! This alone is worth the purchase... After 41k miles, the lag when punching the throttle is gone. Ive been able to run the Camaro 2SS to work and back, about 55 miles round trip and I'm noticing small, but significant variances on the car's drive-ability... Downshifting with the A8 seems smoother, less jerkey. With all the great airflow my NPP exhaust is backfiring a bit less. There goes the neighborhood 5:17am alarm clock. Overall.. I'm very impressed! |
06-24-2019, 08:59 PM | #200 | |
Honestly, it's hard to tell if the Connector Position Assurance and the Independent Secondary Lock shown on the illustration can be moved from one style of connector to the next. If anyone could post a picture of the complete part on their wiring harness when installing the TB, it would be greatly appreciated. |
06-24-2019, 10:01 PM | #201 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Damn, thats a great idea!! I wish I would've seen this post before ordering. I would've inquired about it as well with ZL1 inscribed. . No worries, its hidden anyway. But nonetheless, a very nice touch and another example of why Soler is getting rave reviews.. Well done Mike & Soler Team!!
06-25-2019, 12:17 AM | #202 |
Drives: 2017 Silver SS Join Date: Dec 2017
How come some of the TBs have three or one or no grooves at the bottom of the throttle plate? Just curious if it’s dependent on the vehicle
06-25-2019, 06:21 AM | #203 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Can we get a comparison between your ported throttle body and a stock zr5 throttle body? Trying to decide which tb to go with. I've heard some people have issues running the 95 Tb, and others that haven't.
06-25-2019, 06:22 AM | #204 |
Who Needs to KNOW?
Seeing wiped edges of that phillips begs the question.. can torx A286 stainless be swapped in ?
https://www.mcmaster.com/catalog/125/3140 or https://www.mcmaster.com/catalog/125/3139
ing for grip.
06-25-2019, 09:15 AM | #205 | |
Drives: 2015 Corvette Stingray Join Date: May 2019
There is always at least one at the outlet (bottom). Where did you see one w/o it? |
06-25-2019, 09:27 AM | #206 | |
At low-part throttle, we strongly believe that we have a better response than the 95 mm and you surely do not need a tune. At WOT, and if you cleared the way all along the intake from restrictions (filter, CAI, manifold porting, head's porting, etc.) the 95 mm will be more effective but not by much. We are currently working on a modification of the 95 mm and we think it is going to need calibration. Thanks, Last edited by Mike@SolerPerformanceLLC; 06-25-2019 at 09:38 AM. |
06-25-2019, 09:36 AM | #207 | |
The Phillips we provide are 18-8 CRES, thread locked, and peened. They are not going anywhere. Thanks, |
06-25-2019, 10:16 AM | #208 |
It looks like the one ZOtex posted doesn’t have the bottom grooves, I could be seeing it wrong though
06-25-2019, 10:27 AM | #209 |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
The one I have has a bottom groove/channel and 3 up top. I was holding the TB at an angle and also pushing on the blade to get the 1LE engraving to show up in the photo.
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
06-25-2019, 10:29 AM | #210 |
Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
Just placed my order.
