12-16-2013, 08:58 PM | #1 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Solid subframe bushings or toe/trailings?
If you had to choose between a solid subframe bushing (ADM or Pfadt), or upgraded toe rod & trailing arms, which would you pick?
Application: 2010 2SS/RS M6 - daily driver See signature for mods list (coming soon items expected within next 3 months)
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
12-16-2013, 09:10 PM | #2 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Start with the solid subframe bushings first! They are the foundation of the entire IRS! Actually, if you can swing it financially, do everything all at once! You'll have to lower the cradle to do the driver's side toe link so might as well do it when you have the cradle down for the bushings! Also, when you do the trailing arms make sure you replace the outer bushings if the don't come with the arms.
12-16-2013, 09:18 PM | #3 |
100% agree with everything Mike said!!!! Good Advice!!!
12-16-2013, 09:22 PM | #4 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
I agree^ Solid Subframe bushings first.
12-16-2013, 10:03 PM | #5 |
2010 2SS/RS M6
I just wasn't sure if the step from inserts to solid was as good as the upgrade on the toe rods/trailing arms (with outer bushing).
12-17-2013, 12:41 AM | #6 | |
[COTW 4/13/15]
But if you can swing it, full replacement solid bushings are the way to go. Cradle has to come down anyways but thats jmo. Went with the LSR toe links, trailing arms and they have definitely improved the handling, I also need to get some outer bushings.
12-17-2013, 06:33 AM | #7 |
BL1ZZRD
I had inserts but didn't feel much improvement till I went with the full bushings!
12-17-2013, 06:39 AM | #8 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
You have to drop the cradle a little bit to get the toe rod bolts out anyway. Do it all.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
12-17-2013, 12:45 PM | #9 |
Drives: Chevys at the limit Join Date: Nov 2010
It is best to do them both at once to avoid doing things twice. I also recommend doing the Upper control arm bushings while you are doing the subframe bushings.
Best regards, Tyler 888-308-6007 |
08-07-2014, 08:47 PM | #10 | |
Fight Crime, Drive Armed
Drives: '14 2SS Yelo Maro, HD collection Join Date: Jun 2013
You WILL notice that poly outer bushing the first time you drive it. It gives "feedback" on road condition and things out back don't move around as much.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
08-07-2014, 09:12 PM | #11 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
