07-30-2019, 03:12 PM | #1 |
Drives: '17 ZL1 Join Date: Jul 2016
ZL1 Seemingly Lacks Power
I'm a regular participant of HPDEs at PittRace. I was at the track yesterday and power seemed to be underwhelming on corner exit. Normally, I have to be careful with the throttle to avoid wheel spin, but yesterday, I could just mash the throttle at the apex and wait. My MPH on the straights was noticeably less, to the tune of 6-8 MPH on the ~1/2 mile front stretch.
Overall, my lap times were very consistent, but up 3-4 seconds... ~1:56 instead of the ~1:52-1:53s I can normally achieve on R7s.
My first thought was an intercooler pump problem, but I've ruled that out. The pump is working fine. Unfortunately, the PDR doesn't capture IATs or boost pressure. I know that would be useful, but I don't have it. Anyway, I'm not sure what happened, but I have another track day in two weeks and I'd like to figure out what's going on before then. I've considered unhooking the battery so the computer will reset. Has anyone else had a similar experience with the ZL1? Thoughts?
07-30-2019, 03:32 PM | #2 |
Probably Cat Over Temp kicking in... ECU dumps fuel at your engine to keep the cats from melting but really cuts into power. My brother has a tuned 680 RWHP ‘16 Z06 Vette. When we were at the 1/4 mile track this weekend, on his last run of the day he shut COT off and picked up,*5 MPH* in the 1/4...
07-30-2019, 04:36 PM | #3 | |
07-30-2019, 06:12 PM | #4 |
I would datalog some runs, especially if you’re under WOT for a bit. Not sure if you have HP Tuners, but that is a great way to log it. You’ll be able to review a bunch of data points at once.
07-30-2019, 07:12 PM | #5 | |
I would have loved to have had my laptop at the track yesterday. I certainly would have grabbed some logs. I'll bring it with me to my next track day on the 16th. Before the track day I'll probably drop the exhaust and visually inspect the cats...maybe do a backpressure test too.
07-31-2019, 07:19 AM | #6 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
New, or old tires? R7s fall off quite a bit with age.
07-31-2019, 07:56 AM | #7 |
Drives: 1LEs Join Date: May 2009
On the PDR data, does the Pi Toolbox version have that info? It has a TON more data to look at vs. regular Cosworth Toolbox.
https://www.cosworth.com/products/toolbox/ It looks like it has what you are looking for based on zooming into a screenshot here: https://www.corvetteforum.com/forums...i-toolbox.html |
07-31-2019, 08:14 AM | #8 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Sounds like the PTM or drive mode switch got bumped and the car was pulling power out of corners to prevent traction loss. If your truly running in sport 1 it is very intrusive and will pull throttle at almost every corner, if your on R7's you should be at the level to run RACE mode at the track.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
07-31-2019, 09:16 AM | #9 |
They were brand new.
07-31-2019, 09:28 AM | #10 | |
I understand what you are saying about Race mode. I could absolutely run in Race and I have... but I've also done back-to-back comparisons on R7s with Sport 1 and Race and the lap times are almost always within one second. To me, since I'm just running for fun anyway, the stability control to help save my butt when something unexpected happens is worth the time trade-off. That's why I usually run in Sport 1. With that said, I probably should have ran a few laps in Race on Monday just as a test to help narrow the problem. If I don't figure out the issue before my next track event, I'll move it over to Race for a few laps.
07-31-2019, 09:32 AM | #11 | |
https://www.camaro6.com/forums/showp...5&postcount=75
07-31-2019, 09:35 AM | #12 |
Intake temps will always rob power. On a hotter day your temps are probably soaring into the 170s and up. The ZL1 has a decent system but its not perfect. Do you have a reservoir? They are nice to have so you can check your fluid levels and ensure that you always have fluid pressure on the head of the pump. I can't even count the number of times we have taken the intercooler line off of a LT4 and had no fluid come out. A little air in the line can really shut down the fun.
07-31-2019, 09:41 AM | #13 |
Drives: 2013 C6Z06 Join Date: Nov 2016
No limp mode issues though Travis? I was at Watkins Glen last Wednesday and my car went into limp mode in 2 out of 5 sessions. A stock ZLE and Z06 also had issues and it was only 78 degrees there so I'm wondering about humidity. I am going to re-bleed my intercooler circuit, but I am also wondering if it is some electrical problem from sensors acting up under heat and shutting me down. I get no CEL, only the Reduced engine power warning, then after cooling down, pitting, and shutting it off for awhile it's fine when restarted.
07-31-2019, 11:23 AM | #14 | |
No reservoir. My engine and cooling system is all completely stock and has never been touched. Just to be sure, I'll double-check for air in the lines. I'm thinking about upgrading the heat exchangers anyway.
Thread Tools | |
