Old 07-27-2019, 07:50 AM   #1
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Another New PB of 9.65@143&9.74@143
Got another opportunity to get back to the track after my 9.77 at the Camaro Fest. Temps were a little cooler in the mid 80's on my first pass and DA was about 2200 instead of over 3000 like the fest and temps in the low 90s. My 60' time are still a little off because we have timing pulled out down low to keep from spinning which I did on the 9.74 pass, bad enough I had to peddle it w/1.49 60', that was driver error on the burnout. Second pass we were down to 81 degrees and DA was 2000. Hooked pretty good with a 1.47 60' and then 9.65@143. I just don't know if these Hoosiers that I ran last year are going to hold the power we are going to make by the LS Fest. I've just been worried about breaking the stock axles. Fedx just delivered my DSS axles yesterday so I will have resolved that issue going forward. Still on only 13 lbs and just got my smaller pulley yesterday so I can compare pulleys on the dyno when we get there. Hopefully next week since I didn't get there this week because of time constraints. We are barely pushing this new 2650 but one thing that will hold us back is fueling and I'll know how close we are with this smaller pulley that should make around 16 lbs of boost. I'll keep you updated.
Size:  75.2 KB My 1/8 mile has really picked up and I like that as much as the 1/4 mile pickup
Size:  146.9 KB I added my 9.77 pass for comparison.
Old 07-27-2019, 09:29 AM   #2
steelheadrob
Tactical Garage
steelheadrob's Avatar
Nice work Greg. Are you running one or two nozzles on the meth injection kit?
steelheadrob is offline   Reply With Quote
Old 07-27-2019, 09:53 AM   #3
laynlo15
laynlo15's Avatar
Just 1, 65% meth and 35% water. I think I could have run a 9.50 something last night but there was a big oil down on a twin turbo 68 Camaro and we were already 1.5 hours behind and it was midnight, we had a 2.5 hour drive home so we left before the 1st round and temps when we left it was down to 72 degrees, DA was still high but it was the best weather I could have had to make that happen. We loaded and left about 1230am and they were just starting the 1st round. Had to go. I'll be balls deep at the LS Fest and fingers crossed for good air in September.
Old 07-27-2019, 10:06 AM   #4
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Starting to really roll now Congrats, keep it up.
May have to go to the 15 inch tire .
DapperDan is offline   Reply With Quote
Old 07-27-2019, 10:49 AM   #5
laynlo15
laynlo15's Avatar
Tough call on the 15s, we will get it dialed in better once on the dyno.
Old 07-27-2019, 03:53 PM   #6
laynlo15
laynlo15's Avatar
Looking back I wish I'd had pulled the other head off and had the gone thru and ported. Plus I would have changed the springs again and went with a better spring up to .700 lift instead of the .660 springs if bought with the cam kit.
Old 07-28-2019, 02:13 PM   #7
L78toLT1
L78toLT1's Avatar
Congrats, Greg! Keep it up and you'll be in the 8's before you're done! Great idea on the axles too, are u also upgrading your driveshaft?
I've decided to upgrade my shaft and axles before getting wheels and trying out the drag radials. Given that my car is an m6, there's no way I'm not going to start breaking stuff pretty quickly if I don't beef up the drivetrain a bit.
Baby Blue
Old 07-28-2019, 03:06 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Why .700 lift springs? Bigger is not always better when it comes to valve springs. They are harder on the lifters. It's all a balance when it comes to setting up a valve train.
Congrats on the PB.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 07-28-2019, 05:26 PM   #9
laynlo15
laynlo15's Avatar
Thanks King, Not sure what I'll do on those this winter. Gotta go thru the heads since they are still stock. I'll look at some options for sure. Jim I've already done the Gforce Driveshaft with BMR loop and I will keep going till I run out of fuel and figure out the best route from there. I just want to make it thru the balance of the season and not break anything.
Old 07-29-2019, 07:59 AM   #10
L78toLT1
L78toLT1's Avatar
I'm trying to decide between DSS, GForce, and GMPerformance axles. I'm a little nervous about DSS; I saw in another thread where Parish was snapping his like matchsticks. I'm thinking either one of us would be a little tougher on axles than Parish with our PD blowers even though his car is making quite a bit more power. My M6 is certainly not helping in this regard either.
Baby Blue
