09-10-2017, 02:32 PM | #1 |
Drives: 2017 Yellow 2SS Join Date: Feb 2015
Wheel weights
I just had some new tires installed on my SS and after I bought the car home I noticed they had placed wheel weights on each rim. I never noticed wheel weights when I had the stock tires. Are they supposed to be left on? They look awful. Its as if they placed them where they would be the most visible.
09-10-2017, 02:45 PM | #2 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
i have wheel weights on the stock tires on the inside of the rim, they are noticeable.
09-10-2017, 03:03 PM | #3 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
The wheel weights are necessary due to fabrication tolerances to ensure that your wheel with the tire are 100% balanced. Other wise you will have massive vibration.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
09-10-2017, 03:17 PM | #4 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
09-10-2017, 04:16 PM | #5 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
If they used the clamp on style weights on the edge of your rim take it back, demand they use the type that stick on the inside, and if they damage your rims tell them they're responsible because they should know you do NOT use clamp on weights on Low profile rims.
09-10-2017, 05:46 PM | #6 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
Maxine are stick on
09-10-2017, 07:48 PM | #7 | |
Here is a picture of one of the wheels. The weights are placed like that one all 4 wheels. It wasn't like that when it was stock im sure. |
09-10-2017, 07:56 PM | #8 |
Drives: 2017 2SS Manual Join Date: Apr 2017
that is normal, if it bothers you hit them with a little paint
09-10-2017, 08:00 PM | #9 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
If your stock tires were in better balance than the new tires or better matched to the unbalance of the wheels, they wouldn't have required as much weight.
It might have been possible to rotate the new tires around on the rim to find a position that didn't need as much weight, but you'd probably have to get an agreement with the tire guy to make the extra effort. Although if your tires have match-mounting paint spots on them the tire tech should have known how to orient the tire on the rim for a minimum-weight balance. Otherwise, it is what it is, and good balance doesn't know or care about anybody's appearance preferences. I suppose you could mask around the weights and spray-paint or plasti-dip them black to make them less noticeable . . . that's about all I can offer that won't cost you money for another wheel balancing job that might not come out a whole lot better. Norm
'19 WRX 6M (the family sedan . . . seriously) |
09-10-2017, 11:19 PM | #10 |
That is normal...and yes the stock wheel weight was in the same place just darker color so not as noticeable....
2016 NFG 1SS A8
09-10-2017, 11:31 PM | #11 |
Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
I bought some enamel from Walmart, taped around the weights, then brush painted them black. Up close the paint job is meh but the weights are much less noticeable now.
09-11-2017, 06:17 AM | #12 |
I will say this about the tire tech - on that wheel at least, he didn't do all that great of a job getting the string of weights aligned with the plane of wheel rotation.
Norm
09-11-2017, 07:12 AM | #13 |
Drives: S O L D Join Date: Aug 2016
Yes, that's what I have and they are NOT notceable at all......
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
09-11-2017, 08:12 AM | #14 |
Thanks for the info everybody. I guess I'll just plastidip them black and make them
less noticeable. I can't stand any chrome looking pieces on my car. |
Thread Tools | |
