05-14-2022, 09:55 AM | #1 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
Blower spacer plates, what think ye?
In an all out effort to keep my MAT down in a very hot environment, I’m considering a spacer plate. Has anybody used these? Does anybody have any first (or even second) hand knowledge of it’s effectiveness? Is its results worth the 600 dollar asking price. Thanks for any and all input.
05-14-2022, 10:28 AM | #2 |
Thank you Al Oppenheiser!
Between what? The blower and heads? IMO, the blower makes enough of it's own heat not to be troubled by what comes from the heads. If we're gettin jiggy with the engineering, a cold water jacket for the blower might be more beneficial. But if you're in for a geometry & milling challenge that probably won't affect MAT much, knock yourself out.
If you're not on a road course, you will likely be better off with an interchiller, meth and/or a trunk mounted ice tank. Look to what our Texas brethren are doing for their 1/2+ mile cars... |
05-14-2022, 01:09 PM | #3 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Blower spacers and a heat blanket under the blower was very effective on my Hellcat, dropped IAT temps by 12 degrees. IAT is the Hellcat equivalent of the ZL1 MAT temps.
05-14-2022, 01:12 PM | #4 | |
'20 ZL1 1LE A10,
05-14-2022, 01:26 PM | #5 | |
ZL1 Believer
Thank you for your input. Anybody else with experience?… |
05-14-2022, 02:29 PM | #6 | |
05-14-2022, 03:14 PM | #7 | |
I can't make any real comparisons to how the car heated up and cooled down before and after installing my FII stuff. Heat is not an issue so far, we added substantial advance on my 3rd hit last Tuesday and it ran better. It's a short burst, straight-ahead car.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 05-14-2022 at 07:00 PM. |
05-14-2022, 03:15 PM | #8 |
I have a set of fasterproms blower spacers for sale in the classified section of your interested.
05-15-2022, 06:17 AM | #9 |
Dyno Show Queen LOL
1st...
More capacity 5 gals or more Better IC pump Heat exchanger 2nd... Blower spacers, blankets and lid spacers to aide the above..
05-15-2022, 07:12 AM | #10 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Blower spacer plates do work. I have the FI spacer plates and heat blanket on the bottom of the supercharger on my C6 Grand Sport that has an E-force on it.
Before the plates, I was seeing up to 150F IAT’s after a run. With the plates, no more than 120F. Normal driving, temps were about 50F above ambient before the plates; with plates about 30F above ambient. Now I added these after I did other mods such as bigger heat exchanger, larger reservoir, DeWitts radiator. |
05-15-2022, 09:59 PM | #11 |
ZL1 Believer
Well, that settles it in my mind. FI Interchiller with the spacers and blanket. Just toss it all in. That should help keep things as cool as possible here where it’s damn near 95 degrees 70 percent humidity year round. Now to talk to the man….
05-15-2022, 10:00 PM | #12 |
ZL1 Believer
Thank you all for your input….
05-16-2022, 01:14 AM | #13 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
Do these blowers get hot while out driving around normally, or is this just for track guys, or back to back 1/4mi runs??
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
05-16-2022, 06:43 AM | #14 |
Drives: 2019 ZL1 Join Date: Mar 2019
They get hot. Typically 40F above ambient just driving around.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
