Old 05-11-2022, 06:51 PM   #1
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Front Brake Cooling Deflector
I know some other people have mentioned or talked about this. I know the manual talks about installing this prior to trackdays on non 1LE SS.
Some people have installed it on their 1LE's and I went ahead and did it as well. I only installed the deflector so far, I haven't put the heat shields on yet but I'll put up a video when I do.
Here are some quick reference pictures from before/after incase it helps anyone
Christian1LE is offline   Reply With Quote
Old 05-11-2022, 07:15 PM   #2
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Are you leaving these on permanently or taking them off after track days? Anybody on here leave them on year round?
m6-lt1 is offline   Reply With Quote
Old 05-11-2022, 08:30 PM   #3
andy3213
Drives: 2019 1SS
Mine were installed during PDI and I've never taken them off.
andy3213 is offline   Reply With Quote
Old 05-11-2022, 08:54 PM   #4
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Here is a pic I posted elsewhere. Top is SS 1LE / ZL1, middle is the SS "track" deflector, and the bottom is the CT5-V Blackwing.
RUQWIKR is offline   Reply With Quote
Old 05-11-2022, 09:34 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Will the Caddy piece fit a 6th Gen?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 05-11-2022, 09:38 PM   #6
Christian1LE
I don't drive this car often, usually just to and from the track and some weekend driving here and there. Roads are good where I live so I'll most likely leave them on unless they start scraping a lot.
Old 05-12-2022, 03:27 AM   #7
synolimit
Drives: 22 ZL1 1LE A10
The heat shields?
synolimit is offline   Reply With Quote
Old 05-12-2022, 05:47 AM   #8
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
I went with the CT5 Blackwing, nothing scientific, but perceive better bite and consistent peddle feel. In Florida, anything to reduce or shed heat is a win. I do see less time cruising required for cool down, must add some value.
Timbo-1LE is offline   Reply With Quote
Old 05-12-2022, 07:50 AM   #9
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
But you guys are also installing the tiny heat shields, or at least taking the OE off, right? Otherwise this is a brake shield cooler.
5.M0NSTER is offline   Reply With Quote
Old 05-12-2022, 09:11 AM   #10
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
The 1LE shield is pretty small compared to the OE shield on the non-1LE SS. Even just swapping these bigger ducts on you'll get more airflow to the rotor, just slightly less than what you'd get if you swapped out the brake shield as well. I don't have any data so I could be wrong, but just looking at the components I'm willing to bet that you'll be good just swapping the deflectors and not having to mess with the rotor shield unless you're running some seriously aggressive pads that are outputting a ton of heat or have a decent amount of added engine power.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-12-2022, 11:35 AM   #11
Christian1LE
Even w/o the heat shield it gets much more air to the rotor on the 1LE. But yes, you need to install the smaller shield if you want the best result.
I'm going to do the heat shield tomorrow. Need to get some good thread lock for the caliper bolts.
Old 05-12-2022, 04:49 PM   #12
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Been running with the Track deflectors and small heat shield for years, but not my DD
Old 05-12-2022, 04:51 PM   #13
carguy55
carguy55's Avatar
Great question for RUQWIKR and a part number please
Old 05-12-2022, 05:18 PM   #14
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
Also been running with the larger deflectors and smaller shield on my SS (non 1LE) for a couple of years. I have to be esp slow on some speed bumps as they will drag slightly sometimes. But also not a DD for me. When I started tracking, i did the first 4 or 5 events with the larger disc shield in place, and stock pads. I had no issue, but changed them later. you results may vary... safest to change shields as well. I use red loctite on the caliper bolts. they are not fun to take off, or put back on...... i use a large impact given there is access in the front. ;-)
Eric10905 is offline   Reply With Quote
