12-03-2020, 10:06 PM | #29 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
12-03-2020, 10:10 PM | #30 | |
On a tangentially related note, the search feature is abysmal, it's very difficult to find something specific.
12-03-2020, 10:15 PM | #31 | ||
I like the fact it has both clamps & terminals. I was thinking of adding a weather-tight GM dual plug connector & hard wiring it as shown previously. Quote:
My first memorable paper was on Gallaleo. His ostensible take on our known thinking of the universe influenced my perception of things throughout my life. |
12-03-2020, 11:36 PM | #32 |
Thank you Al Oppenheiser!
Ctek MXS 5.0 works well. Got one of these a couple months ago for $68... price has since gone up.
https://www.amazon.com/gp/product/B00CD44RQO |
12-04-2020, 06:46 AM | #33 |
Hot Camaro
If you're going to cover the car, there are plenty of ways to route wiring through the grille. I have a Schneider Electric tender that has quick disconnect of the cable holding the clamps from the main charging 'brain'. I clip the cables onto the terminals under the hood and then route the cable from the brain in through the grille right next to the passenger side headlight. It pretty much pops directly into the engine bay where I can connect it to the cable with the clamps. The entire brain remains outside of the car, a couple of feet away on the floor/piece of wood.
If you're not going to cover the car, you also have the option of routing out at the back of the hood. I have done this as well, leaving the charging brain resting on the windshield. Both options allow the hood to be closed. But... also if you're not covering the car, you set the hood down without fully closing it and just route the wire out between the hood and front bumper. |
12-04-2020, 07:25 AM | #34 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
12-04-2020, 01:29 PM | #35 |
Drives: SWXXZL1 Join Date: Jul 2020
If you're not aware, there are various quick connect male/female harnesses that can be found for use with the Battery Tender by DELTRAN. Stinkin' amazon, motorcycle shops, automotive supply and some hardware supplies should have them. For example, a short fused harness with ring terminals instead of the clamp harness, various length harness extensions, etc.
"Joe" does a hilarious impression of a slinky toy on stairs.
12-04-2020, 01:32 PM | #36 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Of course, as you point out, you can get those kinds of things for Battery Tenders as well. At one time, they came with several ends. Maybe they still do.
12-04-2020, 01:59 PM | #37 |
Drives: 2018 camaro 2 ss Join Date: Feb 2018
Battery Tender
As Gunkk said. Get yourself a CTEK mxs5.0/12v-4.3Amp. It has all that you will need and it works great. It comes with a 5yr warranty. In fact if you look at the tender that says Camaro and Corvette from GM, they look like the CTEK mxs. The company has been around for years. It charges at 4.3 amps if needed till it reaches the full state,then goes into a maintaining mode.
