Old 12-02-2020, 05:47 PM   #183
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
I left the office at about 5:15. The car had been parked since a little before 9 AM, outdoors. Today's high was about 43 F. One fob was in my pants pocket all day, so may have benefited from my body heat. The other fob was in my coat pocket, which was hanging all day.
When I got to the car, I could not unlock it with the tiny button on the door handle, but I could unlock it with the unlock button on the fob.
I got in, sat down, and the car started normally. No need to put my fob in the cup holder.
When I got home, I put new batteries in both fobs.
We'll see what happens tomorrow, as the weather is supposed to be clear, so it will be another Camaro commute day. FWIW, the commute is about 28 miles each way.
Emoto is offline   Reply With Quote
Old 12-03-2020, 08:48 AM   #184
Emoto
Sure, why not?
Emoto's Avatar
This morning, I brought a single key fob (with new battery) out to the garage with me. (The garage is kept at 45 F). I was able to unlock it using the small button on the door handle.
I got into the car, and it fired right up like it normally should. No need to put the fob into the cup holder. When I arrived at work, I was able to lock the car with the little button on the door handle.
I have no way of knowing, but I wonder if the fob batteries were weak from age, and maybe the car battery was a little low from sitting, and that made the fob hard to pick up? Just an idea.
I won't keep posting about it working normally, but will circle back to this thread if it goes wonky again or if any other action is required.
Old 04-10-2022, 02:04 PM   #185
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Believe it or not both of my remote batteries were dead. So replace them to just be sure before going on a wild goose chase.
Old 04-13-2022, 10:12 PM   #186
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
Open the door with the key. Pull the cap off the door handle and use the key. Then put both pods in the back cup holder to reset the pods.
Casper the friendly G is offline   Reply With Quote
Old 04-13-2022, 10:33 PM   #187
Originally Posted by Razzaa View Post
Over a year since I started this thread and GM still hasn’t found a fix!!
THEN THE DEALER needs to call in a GM engineer to come down from Motown.
Old 09-02-2022, 07:08 AM   #188
Allez
Allez's Avatar
Happened to me for the first time yesterday. No problems starting the car several times, but when hitting the Start button to turn off the car there was a pause for a couple seconds, the engine would stop, and an error message about the fob not being detected. Lights and radio stayed on, even when opening the door. Happened x 3 yesterday, even with my second fob. Replaced the fob battery, so we'll see . . .
Allez is offline   Reply With Quote
Old 09-02-2022, 08:30 AM   #189
Aragorn
Drives: Camaro SS 1LE
Same , two days ago. It was 111f and I was a bit worried. Was able to get in though and fire it up. New battery did the trick.
Aragorn is offline   Reply With Quote
Old 09-02-2022, 09:42 AM   #190
redcoats1976
whats odd is the fob batteries in my 2015 camaro have never been replaced,and i havent had a problem with them.you wouldnt think the 6th gen fobs would use that much more power,would you?
redcoats1976 is offline   Reply With Quote
Old 09-02-2022, 10:36 AM   #191
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
yeah i had similar problem the other day.
replaced the batteries last year. had trouble starting it the other day.said no key detected.
key was in my pocket.
Camaro fanboy is offline   Reply With Quote
Old 09-02-2022, 11:31 AM   #192
Aragorn
Oh, in case it hasn’t been stated, when this happens setting the key fob in the small or rear cop holder can save your butts.
Old 09-02-2022, 11:44 AM   #193
Camaro fanboy
yeah i did that and all was ok. dosnt the car info system tell u when the batteries need replacing?
Old 09-02-2022, 11:51 AM   #194
Aragorn
Mine does not I just get that message that the key fob is not detected.
Old 03-27-2023, 06:33 PM   #195
Bassment
Drives: 2016 Red Hot 2SS M6
I’m in the same situation, both key fobs stopped working. And I’m in Canada so I can’t do the reprogramming for some reason? Is there anything you can do other than bring it into a dealer?
Bassment is offline   Reply With Quote
Old 03-27-2023, 08:52 PM   #196
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
I was told by the salesmen when I purchased my (now traded in 2022 SS ) in conversation about the electronics in the cars these days , he said change the fob batteries every year . It will save you time , money , and a headache. The fob and the car are always communicating , I've been told .
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
