01-01-2024, 12:00 PM | #1 |
Brian
Drives: 2024 Camaro 2SS vert Join Date: Nov 2023
Camaro front camera fix
I recently purchased a 24 2SS convertible and traded in a 2019 Corvette GS convertible. The Vette had a front camera which I found invaluable for parking nose-in. The Camaro nose distance is difficult to judge but there is no front camera to assist. The solution for me is this device: WiFi Car Wireless Backup Camera, GreenYi 5G 720P HD Car License Plate Rear/Front View on Amazon. When powered, it generates a 5G wi-fi signal and transmits the image to your android or iphone via an app called Joytrip. It works really well and saves me a lot of anxiety about parking nose-in. I installed the camera just below the front license plate holder (required in Ontario) so it is not easily visible. It took me a good 6 hours to do the wiring and install the camera. Very pleased with the result.
01-01-2024, 01:06 PM | #2 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
The question I have is what about bugs and stones? Over here in upper IL. we have lots of both.
01-01-2024, 10:21 PM | #3 | |
Drives: 2018 Chevy Camaro convertable Join Date: Jan 2023
01-02-2024, 09:06 AM | #4 |
Hot Camaro
1) Learn how to use your sideview mirrors to gauge where the front of the car is.
2) Back in. Problem solved. |
01-02-2024, 10:18 AM | #5 |
Drives: LT1 Join Date: Mar 2022
Since we only have rear plates in FL, the HOA in this condo complex requires all plates be visible (so only nose-in parking). I just look at my car's reflection off of another vehicle to gauge how close I am in front.
But yeah, back up into any other parking space and problem solved. |
01-02-2024, 10:30 AM | #6 | |
Hot Camaro
I've used the "vehicle next to me" trick for years as well. Once you set your driving position in the car, and you have the car parked where you want it, look -under- the side mirrors. You should be able to identify a relative position under the bottom of the mirror to where the curb or similar should be. When pulling in, you use that as your guide to know when you're in far enough. |
01-02-2024, 03:14 PM | #7 | |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
01-02-2024, 05:43 PM | #8 |
Drives: 2021 3LT RS A10 Join Date: Nov 2021
I use the backup camera to get the rear end near the end of the white parking lines and call it good. The parking lines are usually long enough for the length of the car itself.
