02-04-2021, 10:10 PM | #1 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
ZL1 M6 transmission fluid
I’m looking to change the fluid on my ZL1 1LE 6 speed. What’s everyone’s preference on transmission fluid for these cars? I see that TREMEC makes their own fluid, but haven’t heard much about it. Thanks
02-04-2021, 10:24 PM | #2 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
I put the Tremec fluid in my ZLE. Better shifting at track temps, but worse cold on the street.
02-05-2021, 06:10 AM | #3 |
02-05-2021, 06:54 AM | #4 |
It’s fine on the street. It just takes a little longer to warm up before it shifts smoothly. I made the switch because I was having some issues with quick downshifts at the end of a track session in hot weather. No reason to switch if the stock fluid is working well for you.
02-05-2021, 08:13 AM | #5 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
02-05-2021, 08:34 AM | #6 |
Drives: 2017 ZL1 Join Date: Jan 2017
I went to the Tremec MTF, no differences noted.
02-05-2021, 10:36 AM | #7 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
In my '17 SS 1LE I switched to Amsoil Signature Series ATF fluid and noticed an improvement in how smooth the transmission shifted, so I'll be putting that in my current car in the next month or so.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
02-05-2021, 12:11 PM | #8 |
Drives: Chevrolet Camaro ZL1 Join Date: Sep 2019
I was having issues with notchy shifting especially getting in to first when the trans was cold. I ended up going with Royal Purple and the cold shifting is much improved. I don't track the car (yet) so I can't comment on its performance there. It appears most fluids help with cold shifting or with shifting while on the track but none seems to work the way you would want at all temps.
02-05-2021, 12:44 PM | #9 |
i just called my dealer to get a price on flush and refill said about $250 with fluid included but they dont offer that on saturdays...fun shit
02-05-2021, 06:59 PM | #10 | |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
02-05-2021, 10:49 PM | #11 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I changed from OEM factory fill to Tremec MTF after 2 years and ~10k miles... I see no real difference, only time my car is notchy is when I start it on a cold morning and I have a little resistance getting it into Reverse to back out of garage, and it only takes a firmer push to engage. Once I'm rolling, 1st and 2nd engage easy even on a cold morning/night, but I'm in Los Angeles so cold is ~48 F.
I recommend the Tremec MTF because it's made by Tremec for their 6060, during 4 track days in December it was perfectly smooth shifting. Last edited by SFV1LE; 02-05-2021 at 11:09 PM. |
02-06-2021, 08:55 AM | #12 |
Drives: 2018 ZLE Join Date: Feb 2018
I did the Royal Purple Synchromax last weekend.
02-06-2021, 11:09 AM | #13 |
Thanks for the replies. I ordered some TREMEC HP-MTF
02-06-2021, 11:43 AM | #14 |
Drives: 19 ZLE M6 Red Hot Join Date: Oct 2017
How often you supposed to change the fluid?
