05-04-2021, 10:48 AM | #15 |
From a macro standpoint, $100/hp looks like a pretty good number
'20 ZL1 1LE A10,
05-04-2021, 10:48 AM | #16 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Based on this, strictly from a stock ZL1, I agree that going E85 is the best bang for the buck if you can live with the cons noted above which are fairly minor.
05-04-2021, 10:49 AM | #17 | |
05-04-2021, 10:50 AM | #18 |
A bone stock ZL1 LT4
'20 ZL1 1LE A10,
05-04-2021, 04:28 PM | #19 |
E85
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
05-04-2021, 07:51 PM | #20 |
Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
I’ve seen cars make 640+ whp with just headers and tune pretty good power for dollars
05-04-2021, 09:16 PM | #21 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Headers and a tune? Not possible. Show me the dynographs along with "Just headers and a tune".
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-04-2021, 09:29 PM | #22 |
Yea, my shop is working up a quote to go that route. I know I'll need a high side pump, which is fine because I might end up with a Maggie
'20 ZL1 1LE A10,
05-04-2021, 10:42 PM | #23 |
This article says headers, exhaust and tune was 41 hp
'20 ZL1 1LE A10,
05-05-2021, 06:23 AM | #24 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Headers and tune. E85 sounds good but if you have no access then you are SOL. Headers are on and there no thinking about that plus have to mix ratios of fuel. Best bang for buck all around hands down!
05-05-2021, 06:30 AM | #25 | |
Dyno Show Queen LOL
https://www.camaro6.com/forums/showthread.php?t=517100
05-05-2021, 09:51 AM | #26 |
I didnt do a high side pump because the lead time on the big bore was like 8-12 weeks out! I ended up doing the fore systems triple in tank pump, 32% fuel lobe and 30% injectors, at 866RWHP the high side is all good on E65
2018 ZL1-NFG-A10
05-05-2021, 09:58 AM | #27 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Headers, GESI cats and a tune. The return is real world improved throttle response, more usable HP throughout the usable power band, improved sound and a building block for most future mods.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
05-05-2021, 11:02 AM | #28 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
My understanding is that with the stock fuel pump housing removed you lose the surge tank and even a hard pull or high G turn on an onramp, with under 1/4 tank, could result in fuel starvation. |
