05-02-2021, 09:06 PM | #1 |
Drives: 2012 Chevrolet Camaro SS Join Date: Nov 2015
Tranny Shudder @ 97k miles
Good evening peeps. So I pulled the trigger on a high mileage 2017 SS (about 97k miles now). I didn't notice it when I test drove it but after driving it 1400 miles in the last week I discovered it has the all to common shudder issue. I'm going to call the local dealership to see if it ever had TSB 18-NA-355 performed on it. Assuming it has, is it possible the fluid just needs changing or is the converter probably shot? If nothing else its certainly due for a fluid change but could old fluid cause the issue? If the TSB hasn't been done, should I plan on having it done so late in the transmissions life? I've read up on all the threads on this but I don't think anyone has dealt with this on a high mileage car yet. Not sure how I should go about fixing this. Obviously I want to try the least expensive measures first before I commit to a torque converter replacement. Any advice would be appreciated.
2017 Camaro SS Red Hot 1SS Convertible A8
05-02-2021, 10:06 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
https://www.camaro6.com/forums/showt...527133&page=26
The latest transmission fluid (Mobil 1 Synthetic LV ATF HP, part number 19417577, blue stripe on the bottle and not black) that actually fixes the problem came out in Jan 2019 as part of TSB 18-NA-355, so unless your A8 was flushed with this specific fluid, it can develop the shudder. |
05-02-2021, 10:42 PM | #3 |
2020 Shadow Gray 2SS
I would certainly try a flush (or double flush) before considering a converter...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
05-10-2021, 11:22 AM | #4 |
Long hauler
Adding onto the replies, if the cars been driven on the shudder for extended time then it can come back even with the latest fluid flush.
05-10-2021, 11:26 AM | #5 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Exactly. That's what happened in my case, and it trashed the torque converter. Then they replaced it along with the new fluid and flush again
05-10-2021, 11:48 AM | #6 |
I dropped it off at a local transmission shop over the weekend. I’m gonna start with a flush and see if that helps. If not I’ll make arrangements to replace the converter. I can throw it in 7th gear when on highway and problem goes away. Driving around town 50 mph and slower it doesn’t do it.
10-17-2021, 09:19 AM | #7 |
Drives: 2016 Garnet Red 1SS Join Date: Feb 2011
I had the flush done with the new fluid at about 97k miles. I'm at 102 now and so far so good. Hasn't come back yet.
10-19-2021, 01:00 PM | #8 |
Drives: 2017 2SS Camaro Join Date: Jul 2017
Trans Flush for Shudder Problem
I have read on these forums that some cameras are getting a three flush procedure. I contacted my dealer and was advised that the three flushes was only for vettes. Has anyone heard of this? I am scheduled to bring my 17 SS2 into the dealer next week and they will only do a single flush. Am I at a disadvantage with the single flush?
Thanks. |
10-19-2021, 01:01 PM | #9 |
Sorry, Camaros (damn spell check).
10-19-2021, 04:50 PM | #10 | |
10-19-2021, 11:01 PM | #11 | ||
