Old 03-30-2021, 09:41 AM   #1
Hambo864
Drives: Chevrolet Camaro SS 1LE
HPFP low pressure with tune, normal without tune
Has anyone else experienced their high pressure fuel pressure pump dropping off after having a tune applied but normal pressures on the factory tune? With the base tune, the car spits on moderate to heavy throttle. If I put the factory tune back on, the car pulls hard. I have the logs and the maps if anyone can assist.
2018 SS 1LE
LT2 non ported
Tony Mamo V2 87mm
Roto Fab Intake
DSX E85
Corsa NPP Double X catback
HPTuners
Hambo864 is offline   Reply With Quote
Old 03-30-2021, 03:29 PM   #2
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Do a compare. Open either file, then select compare and open the other file. See if the desired fuel pressures are altered on your base tune.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
