08-06-2018, 06:16 PM | #15 | |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
08-07-2018, 06:21 PM | #16 |
Has anyone figured out which performance mode correlates to tour/sport/track?
Also what about the fact that there is a open and closed%, doesn't really make sense unless it's some kind of reference PWM signal? |
08-07-2018, 07:18 PM | #17 | |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Mode 1 = Sport Mode 2 = Track Mode 3 = Stealth I'm not sure the difference between the open and close % though.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
08-07-2018, 07:58 PM | #18 |
Drives: 2018 Camaro SS Join Date: Mar 2018
08-07-2018, 09:12 PM | #19 | |
2016 NFG 1SS A8
08-07-2018, 09:20 PM | #20 | |
For example: let's say for mode 1 you set the closed to 100 in all cells, but the open to -1 in all cells. The exhaust will stay closed until certain criteria is met such as WOT, then the valves will fully open. I was playing with it the other day and that is the correlation I came up with. You can then adjust the exhaust valve threshold which is different rpm and tps points for the valves to reference the open/close tables.
2016 NFG 1SS A8
08-08-2018, 01:59 PM | #21 |
Drives: 17 white 1LE Join Date: Feb 2017
where do you go in HP tuner software to licence this feature?
08-08-2018, 02:30 PM | #22 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Connect to vehicle
go to Flash --> Read vehicle then Gather info it will show available modules ECM,TCM and FSCM (may be called slightly different name) Click read entire for fuel module Read warning Message comes up that it not a file from vehicle click ok. FSCM file will be generic file and will be under fuel system tab
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
08-08-2018, 06:00 PM | #23 | |
08-08-2018, 06:15 PM | #24 | |
10-03-2018, 09:34 PM | #25 |
Drives: 2017 Camaro SS 1970 chevelle SS Join Date: Oct 2016
Would anyone be willing to post up a screenshot of their tables as guidance? I am a bit confused as to how these tables correlate to the modes/gears. I’d like to make track and sport open 100% of the time and tour closed 100% of the time just as King described.. sorry I am an Hptuners noob. Thanks
10-04-2018, 06:26 AM | #26 | |
Drives: 18 zl1 Join Date: Aug 2017
10-04-2018, 12:43 PM | #27 |
Yeah I don’t think king recommended doing that but used it as an example.
I’ve settled on this: Tour: just turned off loud startup - rest is stock Sport: copied the stock track table into sport Track: all open
10-04-2018, 01:22 PM | #28 |
[QUOTE=Nicul15;10329170]Yeah I don’t think king recommended doing that but used it as an example.
I’ve settled on this: Tour: just turned off loud startup - rest is stock Sport: copied the stock track table into sport Track Yea that’s what I want to do. Turn off rumble start on tour, and leave it the same otherwise. I’d like sport and track to be 100% open. So to do this, do you just set the sport/track say like 7000 rpm close and 0 rpm on the open tables? Sent from my iPhone using Tapatalk
2017 camaro SS A8
FBO With all porting and tuning done by PRAY |
