04-08-2018, 08:40 AM | #29 |
Dyno Show Queen LOL
Thanks..
Added 700 to build
04-27-2018, 07:43 PM | #30 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Any updates?
04-28-2018, 09:10 AM | #31 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Was looking at the Texas Speed website, the only full length headers they have for 599 are the non-cat ones. The ones with cats are 899. Still not a bad deal.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
04-28-2018, 09:55 AM | #32 |
Drives: Red Hot track candy Join Date: Oct 2009
Damn good thing you took a pic of that belt path. yeeyeeyeeyeeeyeeyiiiiikes!
$20 a pony is straight wild wild west times
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
04-30-2018, 11:16 AM | #33 |
Drives: dont have one yet Join Date: Mar 2018
What kind of mpg are you getting? Not that it matters, I'm just curious.
Also, how is does the factory clutch handle the extra power? Thanks. |
04-30-2018, 12:02 PM | #34 |
Dyno Show Queen LOL
The gas milage is the same but I find myself wanting to race more lol.. clutch is fine so far have not thrown drag tires on it yet.. I'm sure if drag tires were on it and tires aren't allowed to slip it be short lived just like every other car.
04-30-2018, 12:09 PM | #35 |
Good to know the car can handle the extra power without a problem. Thanks for the info!
05-02-2018, 01:36 PM | #36 |
Can I ask why you decided to go with the lower set up instead of the upper?
05-02-2018, 07:43 PM | #37 | |
Dyno Show Queen LOL
I think im gonna pull blower and heads and have them ported I may even do the cam..
08-21-2018, 10:33 PM | #38 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
That ATI 918856 pulley can't he found for $325 now. $439 is hest I'm finding. I want the $325 version.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
08-22-2018, 04:05 AM | #39 |
Dyno Show Queen LOL
You were late to the party.. I got lucky apparently whipple ordered some from ATI and the shipment was lost. A unclaimed freight posted 15 of them on ebay now they are gone. That's still a good price..
08-30-2018, 03:41 PM | #40 | |
Train Driver
However I ended up getting the 8.6" (8% Overdrive) pulley instead since i dont plan on running headers. I am not getting alot of information when searching on what belt to use with the Stock upper 2.5" pulley and the 8.6" Lower pulley. If you used the GATES Greenback k080845HD with your 9.1". Mine belt should use a slightly shorter belt. The next size shorter is the K080842HD belt. It is only 3/8" shorter. The circumference difference between your 9.1 and my 8.6 is (.5 inches x 3.14159) or about 1.57". If you subtract that off your k080845HD size its about the size as factory which is the next size under the K080842HD belt. So it appears the factory size might work, maybe???? So does anyone have an idea on what belt I should get. It appears that running just a lower 8.6" pulley with stock upper is not a common combination. Its about the same blower speed as the 2.3" upper though.
2018 Camaro ZL1LE
09-18-2018, 03:17 PM | #41 |
Drives: 2018 ZL1, 2018 Tahoe RST Edition Join Date: Aug 2018
If you did lower pulley why didn’t you do a Cam while you were down there?
09-18-2018, 03:20 PM | #42 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
