11-27-2023, 09:22 AM | #1 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Stainless works 1 and 7/8 primary ls swap headers
Stainless works 1 and 7/8 primary LS swap headers. 3 inch 3 bolt collectors. Typicslly these are a slip fit connection, but i had the flanges welded on for a more permanent solution. These are sold by Hawks Motorsports for over $1200. I had these on my 5.3 swapped 1987 Pontiac Trans Am GTA. The o2 sensors are truck specific to cable driven throttle body PSI conversions harness. Headers removed because I sold the car and the new owner went twin turbo so he had no need for them. Asking $400 plus the ride, or you can pick them up in Chiefland FL. Will be going on ebay if I can't sell them in the next week or so.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. Last edited by The_bald_eagle_machine; 01-19-2024 at 11:30 AM. |
01-04-2024, 11:43 AM | #2 |
Anthony S
Make an offer, not firm on the price...
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
01-19-2024, 11:30 AM | #3 |
Anthony S
Lowered price of these headers to $300 shipped which is less then Speed engineering charges for there headers.
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. Last edited by The_bald_eagle_machine; 01-23-2024 at 09:46 AM. |
01-27-2024, 01:14 PM | #4 |
Anthony S
SOLD!
