08-14-2018, 09:00 PM | #1 |
GM Dark/Clear Tail Lights; sleek and stylish, but are they legal??
Recently I got pulled over for 'no' front license plate. And the cop took a look at my GM Dark/Clear Tail Lights and gave me a 'warning' because they weren't reflective. I was under the impression that this tail lights were approved by DOT? I'm in Texas.
I GM part# 84136777 https://www.gmpartshouse.com/oem-par...RoCPSsQAvD_BwE |
08-14-2018, 09:14 PM | #2 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
Yes, they are legal.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
08-14-2018, 09:36 PM | #3 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Legal
2010 Camaro 1LT V6 (Sold. I will miss her!) |
08-14-2018, 09:40 PM | #4 |
Drives: 2017 Black Camaro SS 1lE Join Date: May 2017
They are legal. Must of been a new cop and is not familiar with all the DOT laws. Did u get a ticket for the no plate?
08-14-2018, 09:43 PM | #5 |
Drives: 2018 NGM ZL1 Join Date: Jul 2018
Reflective rear tail lights? What?
08-14-2018, 10:36 PM | #6 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I’m pretty damn sure the head lights nor tail lights are required to be reflective. Reflectors are required, to which the car has on the sides, front and back, and at the CHMSL and rear fascia. A manufacturer can elect to incorporate them into the lights, though.
I thought the clear portion was reflective anyway, no? |
08-15-2018, 12:25 AM | #7 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
They are original equipment on the redline edition and probably some others.
08-15-2018, 01:24 AM | #8 |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
Yes, they're OEM on Redlines, Hot Wheels and ZL1 1LE.
This link from chevrolet.com states they're street legal. https://accessories.chevrolet.com/pr...tegoryId=12002 Call on the cop if it happens again.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
08-15-2018, 06:14 AM | #9 |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
I'm pretty sure reflectors on the rear are a federal law, but the requirement is met by the reflectors near the exhaust tips. I think auto manufacturers have the option to make it part of the taillight assembly or separate it, which the Camaro team did.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
08-15-2018, 06:18 AM | #10 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Cop does not understand the law.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
08-15-2018, 06:30 AM | #11 |
Drives: Too many to list Join Date: Dec 2011
Yes they’re legal in TX, and every other state.
Per the DPS (Texas Department of Public Safety), pursuant to Texas Transportation Code § 547.322. “Every motor vehicle shall be equipped with at least two tail lamps, unless vehicle was manufactured prior to 1960, in which case your vehicle is required to be equipped with one (1) tail lamp mounted on the rear which, when illuminated, shall emit a red light plainly visible from a distance of 1,000 feet to the rear.” And unless you totally removed your side reflectors, pursuant to Texas Transportation Code § 547.325. “Every motor vehicle shall carry on the rear, either as part of the tail lamps or separately, two or more red reflectors. Rear reflectors on a vehicle shall reflect a red color. Red reflectors required on the rear of a vehicle may be incorporated with the tail lamp assembly. Every reflector upon any vehicle shall be of such size and characteristics and so mounted as to be visible at night from all distances within 600 feet to 100 feet from such vehicle when directly in front of the lawful lower beams of head lamps.” Your vehicle is complaint with all Texas lighting laws, and the laws for any other state in the country. As you see above, your tail lights do not need to be reflective or have a reflector. The reflector is located separately which is perfectly fine. Officer was just giving you a hard time because you were missing the front plate. I’m sure if he felt like you were violating lighting laws he probably would’ve wrote you a citation for it. Sent from my iPhone using Tapatalk Pro |
08-15-2018, 06:39 AM | #12 |
This is worded almost exactly the same as in CT. The bold part shows that it IS illegal to get those clear reflector replacements that some vendors have.
08-15-2018, 09:34 AM | #13 |
Drives: 2004 Honda Civic+2011 Camaro 2SS Join Date: Sep 2013
I could be wrong but I think you are thinking of the running lights on sides and not the reflectors on the rear bumper below the tails. Dont see people replacing those reflectors, just the side running lights. Again, I could be wrong
08-15-2018, 09:47 AM | #14 | |
https://wildhammermotorsports.com/ca...rs-wildhammer/ Based off ecko's Texas definition, and my knowledge of the Connecticut ones, running lights on the side normally have the letter of the law say "running lights must reflect OR display *insert proper color here*" which is why you can get away with changing them legally, but the rear reflectors specifically say "must reflect red". No option to reflect another color.
Thread Tools | |
