02-20-2019, 11:58 AM | #309 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
02-20-2019, 12:04 PM | #310 | |
Drives: 2012 CTS-V Wagon Join Date: Nov 2010
It was Stevenson Chevrolet out in Golden that let me run around in the SS 1LE a few years back - for what its worth they were pretty relaxed about it at the time.
ZL1 Shopping... Former: 2012 CTS-V Wagon, G8 GXP M6, E55 AMG, Mazdaspeed 3, X5M, Cayenne Turbo S, Saab 9-7x Aero, etc..
02-20-2019, 12:08 PM | #311 | ||
Pull your head out of the brand-loyal RDF, there's real data out there indicating there's still a lot of ground to cover.
02-20-2019, 03:05 PM | #312 | |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
1. that article is from February 2017 2. the A10 in the ZLE has different calibrations, so does the differential, it also has an additional cooler 3. it is obvious the ZLE A10 is not for you, so move along
19 ZL1-1LE A10
02-20-2019, 03:06 PM | #313 |
Drives: 2018 ZL1 NGM Join Date: Jan 2018
I concur. In track mode, this 10-spd aggressively downshifts while I’m braking, even more so into turns. It’s like it knows how I would be shifting if I were driving a manual. I wonder if the programming is using algorithms based on inputs from the accelerometer to determine optimal shifting??
However it does it, this thing is wild and always seems to be in the powerband. I traded a 2014 Camaro SS manual for this car and I do not miss the manual one bit. 10 speed is like no other tranny I’ve ever driven. I was told the 10-spd was intuitive but I did not believe it until I test drove it. Car had 3 miles on it when I test drove it. I put about 19 miles on it during the test drive and that’s all it took for me to fall in love with the 10-spd programming. If the 10-spd in the ZLE has programming that is as aggressive (or even more) than my ZL1, it’s going to be mean!! |
02-20-2019, 05:17 PM | #314 | |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
🔺22 RS E TRON GT
🔺21 Model S Plaid |
02-20-2019, 08:29 PM | #315 | |
02-21-2019, 06:51 AM | #316 |
Question about the A10: In the official Chevy track prep PDF (page 4) I notice they recommend changing the A10's ATF after every track session. What kind of unicorn blood is required for that, and what does a dealer's flush cost? Are any of you actually doing this? If you don't, will the service writers get uppity and try and void the warranty?
02-21-2019, 07:15 AM | #317 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
(DEXRONŪ ULV Automatic Transmission Fluid) as listed
As long as you document with receipts, mileage and time, you are safe |
02-21-2019, 08:27 AM | #318 | |
02-28-2019, 07:01 PM | #319 |
Drives: 512M Join Date: Jan 2014
Does anyone have dates that the new 1LE's with the A10's will be showing up on dealer floors?
03-01-2019, 02:01 AM | #320 |
Thank you Al Oppenheiser!
03-01-2019, 03:52 AM | #321 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
BTW, the SLE you test drove...did you buy it? If not then that is why they don't just let people test drive the ZL1. The A10 IS telepathic. At least it seems like it is. This thing predicts what you're gonna do and it has an instantaneous response time. Any little input into the throttle and the trans is ready to slam your head back into the cushion. And I'd put my money that the A10 in the ZL1 is on par with the best transmissions on the planet. Seriously, the trans makes this car what it is. I would not have bought it if it did not have the A10 and now that I do have one (standard ZL1 that is) I can say it was worth it. If you somehow think that the A10 will not live up to your expectations then I gotta tell ya, you're wrong. |
03-01-2019, 05:19 AM | #322 | |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
The A10 is only a slightly better version of the A8 found in the Corvettes. I drove a ZL1 A10 on back roads and the verdict is this - the computer is always trying to learn YOU and decides when to shift. It was frustrating at times with constant 'SHIFT DENIED' messages being thrown at me. You are instantly hit with the realization that the driver is not in control. P.s. I am an advanced HPDE driver so I wasn't shifting or chucking in the car unnecessarily. The only chance an Automatic can get to being 'telepathic' is getting to a Dual Clutch. All that A10 does for the ZL1 1LE is pander to the masses and Add Weight which further dilutes this car. The A10 is is simply a reinforced torque convertor transmission. Al Oppenheiser was dead against having an Auto in this car for all the reasons stated above. |
