Vararam
Old 05-24-2018, 04:03 PM   #1
crowcoll
Drives: Camaro 2014 LS
2014 LS door panel upgrade to SS with ABL?
So my used 2014 Camaro that I just got is in almost pristine condition but my driver side door panel has a lot of nicks and scratches on it like someone kept hitting it with a watch or something. Anyways I have been thinking about switching the door panels out. I would like to know if I can upgrade to the SS door panels with the ABL in them already as I'm planning to get the dash ABL kit. Will the SS door panels fit the LS with no issues/modification needed? Just want to make sure before I go out and buy them first.
Also if I can do this with no real hassle, what will I need to get the ABL in the SS door panels to work with the LS Camaro?
crowcoll is offline   Reply With Quote
Old 05-24-2018, 04:11 PM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
yup, the SS panels should fit perfectly.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 05-24-2018, 08:45 PM   #3
crowcoll
Thanks for the quick reply. Forgot to ask the years of the SS door panels. 10-15 Should all go in easy right?
Old 05-24-2018, 09:47 PM   #4
orange devil
Drives: 2019 SS 2019 mustang GT
Yes they're all interchangeable and Gen 5 DIY sells the pigtail to tap into your window switch to hook up the ambient lighting.
orange devil is offline   Reply With Quote
Old 05-24-2018, 10:08 PM   #5
crowcoll
Awesome now I just need to find a good deal on those panels thanks for the help
Old 11-28-2018, 03:24 PM   #6
crowcoll
Sorry to bring up an old post but I'm finally getting ready to do this and got 1 more question before I pull the trigger. Now I need to get the Clear Dash trim as well for that abl kit. Those are all interchangeable to the LS camaro as well right?
Old 11-29-2018, 08:36 AM   #7
orange devil
Yes ..they just pop out..but they wont light up unless you get the kit from gen5diy
Old 11-29-2018, 08:57 AM   #8
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
For 2014 camaro ls, you will have the abl pigtail already in your door wiring harness to use on the SS (abl)or such door panel. I installed zl1 (abl) door panels and it was plug and play from factory. Now your dash abl seems to require the gen5 harness. I did not do that yet so I cannot speak to the requirements for dash. Good luck.
SIM GhostrdrZ is offline   Reply With Quote
Old 11-29-2018, 03:52 PM   #9
crowcoll
Thanks for all the info everyone I appreciate it.
5th gen, door panel, ls camaro, ss camaro
