07-06-2017, 09:43 PM | #1 |
Drives: 2012 Camaro SS/RS Join Date: Feb 2016
Smallest Rims I can put on? & best tire?
Can't seem to find the answer but what's the smallest rim I can go with before having to change the brakes on my SS? Also what the best tire out there for a street/Drag radial? Been looking at M/T S/S tires but the nitto NT555r is more in my price range as of right now. Any other tires you recommend?
2012 Camaro 2SS L99, LT KOOKs Headers with Highflow Cats, Straight Piped, BTR Stage 2 Cam w/ tune and DOD/AFM delete
07-06-2017, 10:12 PM | #2 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Some 17s will fit. It requires the roller skates to be cut off the front brake pads or pads changed to ones without them. I'm currently running racestar recluse 17x7 in front and 17x10.5 in the rear and I'm lowered 1" with stock lcas. The mt et street ss are going to be better at the strip than the nittos but they wont last as long with a lot of street driving.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
07-06-2017, 10:12 PM | #3 |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
18s is the smallest wheel I believe. However, you'll have to cut the wheel weights off if I remember correctly. However, certain 18" wheels will not fit.
07-06-2017, 10:14 PM | #4 | |
07-06-2017, 10:51 PM | #5 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
SOME........ will fit
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
07-07-2017, 01:52 AM | #6 |
17" welds will fit with bmr control arms.
07-07-2017, 08:27 AM | #7 |
Drives: Camaro Join Date: Mar 2013
I have Weld 17s front and rear. If you are stock ride height, stock LCAs will clear, just relocate the emergency brake cable. If you are lowered, you will need BMR LCAs, I have the adjustable model and still relocate the emergency brake cable.
As for tires, pretty much any 305/315 will fit. Which one depends on how you plan on using them and if you plan to DD the car and how often you plan to replace them. |
Tags |
drag, radials, rims, street, tires |
Thread Tools | |
