Old 03-13-2017, 02:23 PM   #15
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
Yes, 1LE springs are most definitely different than a stock 1SS/2SS as I said in the original post.
Eibach lists the spring rates for stock 1ss/2ss and their own springs on their website, so does Phastek... However I don't have not been able to find the stock 1LE spring rates... Has anyone else?
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 03-13-2017, 02:46 PM   #16
F1FTY
Drives: 2018 ZL1
Not yet. Dropping off my 1LE springs this week at a racing shop locally to have them tested. Will post results.
Since the kit requires a reflash of the shock software, I'm expecting it to be a decent increase in rate.
F1FTY is offline   Reply With Quote
Old 03-13-2017, 03:22 PM   #17
RideZX6R
RideZX6R's Avatar
Oh awesome!
Thanks dude - Shoot me a PM when you get the info if you don't mind
-Seven
'24 911 T (ordered)
Formers...
Old 03-13-2017, 03:38 PM   #18
RobertSmith
Drives: Mitsubishi Evolution X
I don't understand this to an extent. The point of the 1LE is the package.
But it's just a car, so party on.
RobertSmith is offline   Reply With Quote
Old 03-13-2017, 06:58 PM   #19
F1FTY
Drives: 2018 ZL1
Oh awesome!
Will do!
Hopefully the snow tomorrow isn't too bad so I can get out to the shop!
Old 03-13-2017, 07:12 PM   #20
RideZX6R
RideZX6R's Avatar
Updated original post with pics
-Seven
'24 911 T (ordered)
Formers...
Old 03-14-2017, 10:44 PM   #21
RideZX6R
RideZX6R's Avatar
Updated original post with video https://youtu.be/mW2oMKnozvI
-Seven
'24 911 T (ordered)
Formers...
Old 03-15-2017, 07:28 AM   #22
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Humm, hard to tell in your pic, as it's dark and far away, but it seems like the back dropped a little, but the front didn't...looks like your gap is more in the front?
Odd thing is your car sat higher than mine stock, my car seems to sit just as low as your car does with the lowering springs, just with even gaps front and back (I checked, I'm two tight fingers between the tire and fender on all four corners).
Old 03-15-2017, 07:38 AM   #23
Casalino
Casalino's Avatar
Drives: 17' 1LE BLK
Let the springs settle in. Then do a before and after pic. I have to assume there will be a difference in ride height. Just needs to settle
Casalino is offline   Reply With Quote
Old 03-15-2017, 07:55 AM   #24
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Springs "settle" very quickly...some really don't at all, the whole spring settling thing really is kinda an old wive's tale with modern spring technology. My last three spring installs - two didn't budge, one did maybe 1/8". Most of the settling is the suspension from being lifted off the ground, and a few decent miles of driving should take care of that...
Old 03-15-2017, 01:38 PM   #25
RideZX6R
RideZX6R's Avatar
I'll admit my house and therefore garage is on an ever-so-slight incline so the car might sit *slightly* tilted to the rear... maybe 1-2 degrees in a grade.
That being said I feel like my car might've sat a little higher than other 1LEs - maybe because it was an early model (got it in November, first in the PNW that I'm aware of)?
In any case... I'm unsure what I'd like to do - If Phastek gets back to me on the spring rates of their springs, I might try them
-Seven
'24 911 T (ordered)
Formers...
Old 03-15-2017, 01:42 PM   #26
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Nothing to do with build date, mine was built in November too...so who knows. May have something to do with the MRC holding it back, as the SS 1LE calibrations are different then the SS, and I can 100% guarantee you Eibach didn't test these on an SS 1LE.
Old 03-15-2017, 01:47 PM   #27
RideZX6R
RideZX6R's Avatar
They were released long before the 1LE was even announced as far as I know - So you're right.
I'm hoping @F1FTY gets his info on spring rate tests for the 1LE springs soon. Will take those rates and then research some other spring rates and decide what I'd like to do.
Have a PM into @Ricardo@Phastek as well for Phastek's spring rates
Will probably make a call in the next week or so - However the car is fine to drive and comfy on the broken pavement til then
*edit* after some quick math... Eibach is about 20% stiffer than OEM, Phastek lists their springs at "20-25% stiffer than OEM" - Which is likely to say that, they likely would "ride" the same, but might lower more.
-Seven
'24 911 T (ordered)
Formers...
Old 03-15-2017, 09:12 PM   #28
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
I hope you guys aren't tracking your cars ... because they will not handle as well as stock since these are lowering springs for the softer SS suspension and are no longer matched to your 1LE shocks....
aa406079 is offline   Reply With Quote
