06-22-2022, 07:31 AM | #1 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Motul 660 Voids Warranty?
Hey C6 Fam,
I am prepping for my track day for NCM at Camarofest and the dealership I used to go to perform my brake fluid on my old 2016 SS Camaro didn't have any problems changing the fluid. Now when I get my 2022 SS 1LE and I asked to replaced factory fluid with Motul 660 they claim it will void warranty. I'm, like what warranty? The whole car? Have you'll heard of such a thing? They said they will be held liable if the car underperforms and cause issues due to brake fluid put in. Does it comes with DOT4 from the factory? This my first 1LE as my last one had DOT3 and needed to be changed GM ACDELCO PART# 19299570 (Dealer Recommends) vs Motul 660 I plan to use.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
06-22-2022, 07:51 AM | #2 |
Drives: 22 1LE Join Date: Mar 2022
Both fluids are DOT4. Did the dealer say why it would void the warranty? If it's for using a non OEM fluid, I believe that would be against the Magnuson-Moss Warranty Act.
https://www.amazon.com/Genuine-GM-Fl.../dp/B00BK7LXBW https://www.motul.com/us/en-US/produ...x0-500l-us-can |
06-22-2022, 07:54 AM | #3 |
Try printing out the Chevrolet Track Preparation manual and showing it to them. The one I have (2017) says for track events or competitive driving, it is recommended to change the brake fluid with a high performance brake fluid that has a dry boiling point greater than 279 degrees C (543 degrees F). Also says DOT-4 brake fluid.
06-22-2022, 07:56 AM | #4 |
It's just more ultra defensive liability BS from the dealership. The Motul 660 is a great fluid, costs more than that GM DOT4 fluid, it's probably not the same (and superior).
Also, there is no such thing as a single "warranty", the car comes with several warranties, not even sure which one they think would be voided by 3rd party brake fluid—probably powertrain, but then IMO this falls squarely under Magnuson-Moss, you are trying to use a superior aftermarket fluid alternative without modifying the car.
06-22-2022, 07:57 AM | #5 | |
06-22-2022, 08:21 AM | #6 | |
BLUPRINT_1LE
06-22-2022, 08:25 AM | #7 | |
BLUPRINT_1LE
06-22-2022, 08:28 AM | #8 | ||
BLUPRINT_1LE
06-22-2022, 08:51 AM | #9 |
Drives: 2020 1SS 1le Join Date: Apr 2019
Just don't go to the dealer man.
06-22-2022, 09:01 AM | #10 | ||
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
06-22-2022, 10:07 AM | #11 |
never had any issues used to take my car to the dealer !
06-22-2022, 10:43 AM | #12 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Check your brake fluid reservoir cap. It will have "USE ONLY DOT4" printed on it if the car was factory filled with DOT4.
https://www.camaro6.com/forums/showt...php?p=11061563 |
06-22-2022, 12:38 PM | #13 |
BLUPRINT_1LE
FYI: I just found out from a buddy of mine. If you wanted to track your car with factory specs. The factory fill DOT4 fluid from GM is made by Dynatex and has a dry boiling point of 509°F / 265°C
06-22-2022, 01:47 PM | #14 |
There you go, the Motul 600 RBF has a 594 °F boiling point, and the 660 RBF has an higher one of 617 °F.
