11-25-2021, 10:12 AM | #15 | |
11-25-2021, 10:12 AM | #16 | |
Drives: Chevrolet Camaro ZL1 1LE: Stage 5 Join Date: Sep 2021
Katech Stage 5, Magnuson 2650R, Max effort CAM, Johnson 2110-K Spec Lifters, Trend 3/8-.080 Pushrods, 103mm Katech throttle body and Snout, Billet Valve Covers, Billet Oil Pump, 160 degee Thermostat, 2" ARH long tube headers, catless 3" to stock NPP muffler, Big Gulp, CNC Machined Heads/Head Chambers, Griptec Upper and a bunch of other goodies!
861 RWHP 723 RWTQ |
11-25-2021, 10:16 AM | #17 | |
861 RWHP 723 RWTQ |
11-25-2021, 10:18 AM | #18 |
Honestly I wouldn't be surprised if the 555r2's hook better at higher speed then your drag pack with MT's. The MT's are probably the best there is at the track on a prepped surface but on the street they seem to do weird stuff...like act like they are hooked up then break loose. Also the street tears them up like a cheese shredder and when the tread starts to ball up they lose a lot of grip.
2016 NFG 1SS A8
11-25-2021, 10:39 AM | #19 | |
861 RWHP 723 RWTQ |
11-25-2021, 11:13 AM | #20 |
Yea the only thing some what close to those specs is their 345/30/19 which should fit your stock wheels.
2016 NFG 1SS A8
06-25-2022, 11:44 AM | #21 |
So, now running Mickey Thompson Street ET SS's 325/30R19. Still struggling to get traction from a dig and at highway speeds when applying power the ass ends tends to sway back and forth. Wondering if the softer sidewall is causing this instability...
So now what, Nitto 555R2? Michelin Pilot Sport Cup 2's to maintain the highway stability? Smaller wheels with a larger tire to gain some sidewall flex? Any concerns with this combo yielding similar highway instability issues?
861 RWHP 723 RWTQ |
06-25-2022, 11:54 AM | #22 | |
06-25-2022, 12:50 PM | #23 |
I see they make one for the Magnason line as well, did you install this yourself? Does anything have to happen to your tune for this controller to work?
861 RWHP 723 RWTQ |
06-25-2022, 07:27 PM | #24 |
No, I had the shop I use put it in. Didn’t look bad though. Actuator is cake to mount in place of the vacuum one. We mounted the control box under the dash, going through the grommet where the air tube used to be (or at least I thought that was the plan lol). They bent up a small bracket to put the boost dial in the glovebox since I wanted to keep the interior uncluttered. I have not made any tuning changes for the Smoothboost and don’t feel I will need to since you don’t need to retune turning the boost down, it’s usually if you go up past where you were last tuned at. I’ll have my tuner double check it when I see him on 7/11.
