04-06-2021, 08:43 PM | #1 |
Drives: 2021 camaro ss 1LE Join Date: Dec 2020
1LE/ZL1 fuel system differences
Hey, I have a 21’ 1LE that I plan to put a Maggie on and I’m looking at making similar power as the ZL1, maybe slightly more. I have read in places that the 1LE might have different fuel system components than the SS? What exactly would I need to upgrade? Also, I’m looking for opinions on piston ring gap (I would rather do water/meth if that alone is safe) thanks!
04-06-2021, 09:26 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
The 1le share the same fuel pump in the tank as the Zl1 so you'll have to upgrade the High pressure pump and injectors. As far as ring gap I'd talk to an actual engine builder they will be able to sort you out.
04-07-2021, 05:17 AM | #3 |
04-07-2021, 08:46 AM | #4 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
If all you're looking for is ZL1 power (~550whp), you can safely get there on the LT1 fuel system & bottom end.
Baby Blue
04-07-2021, 10:23 AM | #5 |
I never really researched it but for some reason I was thinking they would hit close to 600whp but that’s not right. I would like to be 600-650whp range
04-07-2021, 01:07 PM | #6 |
Stock ZL1's are usually around 550whp. To get to 600 - 650, you will need the LT4 hpfp and injectors.
Baby Blue
04-07-2021, 05:08 PM | #7 |
04-07-2021, 06:55 PM | #8 |
If you add the LT4 fueling, you can add some E into the mix. That will help cool the charge significantly and help prevent an issue with the ring gaps. I know that statement will stir the pot for some, but every single grenaded LT1 stock short block I’ve seen was due to a fuel or tuning issue. Every time, without fail. Fuel it right and you’ve done yourself a huge favor.
04-07-2021, 07:16 PM | #9 | |
04-07-2021, 07:21 PM | #10 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
*Pulley size targeting no more than ~ 7-8 PSI boost? |
04-07-2021, 08:06 PM | #11 | |
Sure, but I’d use a 50/50 water/meth mix instead of just meth. You’ll only need 6-7 psi of boost to get to that power level anyway, so not much heat there thankfully.
04-08-2021, 09:58 AM | #12 | |
I offer complete power packages to meet your goals Our Street brawler package features supercharger, cold air kit,LT headers JRE custom tuning for up to 580 RWHP max Add our LT4 fuel system upgrade for up to 615 on 93 octane. Ring gaps are a non issue if tuning and fuel systems are correct. We have Many cars with totally stock long blocks plus our Terminator cam and blower on E-60 making 750 RWHP reliably for years now.
www.jannettyracing.com
04-08-2021, 02:01 PM | #13 | |
04-09-2021, 07:41 AM | #14 |
You do not need water meth and I strongly recommend against it.
