Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 03-12-2024, 03:10 PM   #309
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Originally Posted by morepowerjoe View Post
Very AWESOME! Great job!
1,000hp IS NEVER ENOUGH!!!
Vicster is offline   Reply With Quote
Old 03-12-2024, 04:59 PM   #310
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Thanks Vic.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-12-2024, 08:22 PM   #311
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
Congratulations and very nice job! Your car sounds awesome!!!
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 03-13-2024, 01:41 AM   #312
morepowerjoe
Thank you sir.
Old 03-13-2024, 05:01 AM   #313
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Sounds healthy to say the least. Nice job!!!
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
acutron42 is offline   Reply With Quote
Old 03-13-2024, 08:53 AM   #314
morepowerjoe
Thank you.
Old 03-13-2024, 08:58 AM   #315
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Sounds awesome Joe!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 03-13-2024, 09:00 AM   #316
morepowerjoe
Originally Posted by Ashen 6.2 View Post
Sounds awesome Joe!
Thank you buddy.
Old 03-19-2024, 01:54 AM   #317
morepowerjoe
Just an update but it runs awesome! I'm so happy. No more oil leaks or lifter tapping. My tuner is really good and has been slowly increasing timing. With every little bit of timing it just gets faster and faster. I just stated to go wot a few days ago after a decent break in period. Like I said I'm just so happy everything turned out so good!
Old 03-19-2024, 03:44 AM   #318
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Glad to hear it, always a great feeling when things go right.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-19-2024, 03:45 AM   #319
morepowerjoe
Yes it is. Thanks Joe.
Old 03-28-2024, 06:17 PM   #320
morepowerjoe
So I changed the oil with the break in oil after 20 minutes and then after 250 miles with the break in oil to conventional oil. Now I have 460 miles on the conventional oil and am wondering when I should change it again. What are your guy's opinions?
Old 03-28-2024, 06:40 PM   #321
Joe.G
Joe.G's Avatar
I would probably dump it at the 1,000 mile total mark.
SCT X4 Dynosteve,
Old 03-29-2024, 05:15 AM   #322
morepowerjoe
Thanks Joe!
