TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
View Poll Results: Horse Power at Crank
800 - 825 Horse Power 0 0%
826 - 850 Horse Power 1 16.67%
851 - 875 Horse Power 0 0%
876 - 900 Horse Power 0 0%
901 - 925 Horse Power 1 16.67%
926 - 950 Horse Power 1 16.67%
951 - 975 Horse Power 0 0%
976 - 1000 Horse Power 1 16.67%
1000+ Horse Power 1 16.67%
Good forbid - Engine Failure... 1 16.67%
Voters: 6. You may not vote on this poll
Old 03-03-2020, 11:17 AM   #1
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Talking The "WildZL1" Build Journey- Ends with 427ci & 2650 Magnuson
I debated a long time wither to post my build, I figured it may help someone or at least be amusing. It starts with a replacement for my previous 13" ZL1 dream car. My wife and I shopped around till we found this 13' ZL1.
1,000hp IS NEVER ENOUGH!!!
Vicster is offline   Reply With Quote
Old 03-03-2020, 11:21 AM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
In!!!
Hopefully one of the things is replacing that gas cap door lol
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-03-2020, 11:24 AM   #3
Vicster
Vicster's Avatar
Drives: 13' ZL1
We will start with the engine.
Got the car home and it has been 3 weeks so started to dismantle the car and the engine. So far everything is straightforward. Took about 2 days to pull engine, bagged and labeled everything. I had previously moved the billet pulleys over from my red car. My wife pulled the engine while I guided it from underneath.
Old 03-03-2020, 11:33 AM   #4
Vicster
Vicster's Avatar
Drives: 13' ZL1
Engine tear down
Yes, I have no garage. My shop turned out to be our living room. I tell you I have the greatest wife in the world. Tear down and ready for the machine shop.
Old 03-03-2020, 11:36 AM   #5
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Does she have a sister??
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 03-03-2020, 11:42 AM   #6
Vicster
Vicster's Avatar
Drives: 13' ZL1
Talking New parts and parts prep.
Some of the new parts and some of the parts prep. My wife and myself performed all the work on the car, I had a machine shop bore and check the block and balance the crank. I balanced and notched all the pistons for the oil squirters, then balanced and roto-peened the Eagle 3D2000 connecting rods and gave the balance weights to the machine shop. Sent the heads to Texas Speed for a 5 axis port job, the valves are all new sodium filled intake and Inconel exhaust valves, BTR .660 dual valve springs and titanium retainers. I disassembled and cleaned them (there was allot of crap in them from Texas Speed) and ported the exhaust some more to match the headers. Fit crank bearings, had to use 2 sets one of them 0.005 smaller, mixed and matched to get clearances. The block was immaculately clean from the machine shop! Wisco pistons were perfect, upgraded to thicker tool steel wrist pins.
All parts were inspected, measured and cleaned (I used a sonic cleaner on almost all the parts) before being used / installed!
Old 03-03-2020, 11:46 AM   #7
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
Thats awesome that you are working out of your living room doing everything yourself, love to cat chilling next to the engine lol. Whats the plan for the engine/ power adder to get to 1000+hp?
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 03-03-2020, 11:59 AM   #8
Vicster
Vicster's Avatar
Drives: 13' ZL1
Answers
1. I did have a new fuel door painted to match the car, have not installed it yet.
2. That is cheating, getting to the end first. I am still doing the road driving tuning, dyno should be in a couple of months. But, I am over driving the super charger 40% and I designed my own cam, close to a BTR stage 3 but with gentler ramp rates.
Old 03-03-2020, 12:05 PM   #9
Vicster
Vicster's Avatar
Drives: 13' ZL1
More engine work
Fitting the bearings for the crank and connecting rods took awhile, I wanted make sure they were perfect. Some pics are just to show what I was doing, do not read into the dial readings... Prep and painted block, final clearance checks and it is assembly time.
All Bolts Replaced with ARP Bolts where possible
Old 03-03-2020, 12:13 PM   #10
Vicster
Vicster's Avatar
Drives: 13' ZL1
Porting
I ported the supercharger and the snout (I could not find pictures of my supercharger but these pretty much show what I did). Must have removed over 2 cups of aluminum (picture of shavings is what I took off 1 side of the supercharger).
All the parts that I could spray with Moly and baked in the oven @250* for an hour, IE: pushrods, rocker arms, oil pump gears and housing, timing gears, rocker arm trunnions and bushings, valve stems, valve springs and retainers, wrist pins and so on...
Old 03-03-2020, 12:28 PM   #11
Vicster
Vicster's Avatar
Drives: 13' ZL1
More engine assembly
Installing a piston to check clearances and deck height. Then installed oil squirters, marked pistons and notched them for clearance. Installing piston rings, installing pistons and torqued rod bolts by measuring bolt stretch, worked out to 100ftlbs. Installing aluminum rear galley plug and cover I used this nifty guide.
Old 03-03-2020, 12:42 PM   #12
Vicster
Vicster's Avatar
Drives: 13' ZL1
Engine assembly continues
Cam install and degree. Valve to piston clearance. Oil pump fit check and chain clearance then permanent after cam degreeing. Installing and centering the oil pump gears with feeler gauges. Also checked cam end play. It took me approx. a year to come up with the cam specs. and had Comp Cams grind it for me using a billet blank. It uses LXL lobe profiles so the valves closing is gentler. I also ported the oil pump and moly coated the gears and pump housing.
Old 03-03-2020, 12:49 PM   #13
Vicster
Vicster's Avatar
Drives: 13' ZL1
Still more, almost ready to install back into car
Installed front cover, oil pickup with an Improved lock aligned and installed oil pan. Tapped all the head steam vents for threaded fittings, made rear vent tube assy. Verified fitment with heads and supercharger. (people with a sharp eye will notice that I have not ported the supercharger yet)
Old 03-03-2020, 01:07 PM   #14
IKILLEDSUPERMAN_ZL1
Awesome pics!
