TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 05-29-2019, 08:48 PM   #1
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Chris49066SS Build Thread GPI
Mod List
Induction & Exhaust
JRE Race Scoop
Z-28 cold air intake
Nick Williams 102mm throttle body
LOD X-1 Intake Manifold w/ 102mm snout
FIC 850cc Injectors
GPI ported heads w/ LS3 hollow stem intake valves
TSP 2" long tube headers w/ JetHot ceramic coat
Jegs turn-downs
Dyno tuned by Ben @ GPI
525rwhp@7600rpm
407 ft/lbs@6100rpm
Valvetrain
11:1 compression ratio 93 octane
Powerbond Damper
GPI SS4 cam (Flycut)
CHE trunnion upgrade kit
PAC .700 valve springs
GPI 5/16" hardened pushrods
GM racing lifters
LS2 Dogbone style dampener
Cometic head gaskets
Mighty Mouse Wild catch can
Drivetrain
ADM transmission cooler
Circle D 5C torque converter
GM 1LE 3.91 gears
Suspension
Front Sway bar removed
Pegasus solid cradle bushings
BMR solid motor mounts
Prothane polyurethane transmission mount
BMR trailing arms, poly outer bushings, non-adjustable
BMR toe rods, non-adjustable
SPC camber bolts
Wheels & Tires
Race Star 17x10.5 rear wheels & Mickey Thompson ET Street S/S
Race Star 17x4.5 front wheels & M&H bias ply 28x4.5s
Hurst Line Lock
Weight Reduction
Removed passenger seat and rear seat
Exhaust (headers w/ dumps)
Front crash bar
Front sway bar
Washer bottle and lines
Trunk/everything except battery & wall lining
Floor mats
Some interior panels
3,740 lb race weight
3,530 lb without driver
Cosmetics
Heritage Grill
Bests as of 16 November 2019
60' - 1.564
1/8 - 7.084
1/4 - 11.079
Well, I felt like its a little overdue but I wanted to start a build thread. Its going to take a minute to catch it up, but I have most of the pictures I took from many of the mods, even if there aren't really all that many mods. I bought the car in March of 2015, a completely stock 2010 Camaro SS/RS, with 24,000 miles. Its a west coast car, so it has seen almost no road salt. It was at first a mild mannered daily driver with the headers and cold air intake that I installed, but that just wasn't enough for me, so in 2018, I started slowly transforming it into a weekend cruiser with no road courses in mind, but a high RPM drag racing car. Thanks for viewing, and plenty more pics are on the way!
Here is the first one the day after I drove it off the lot, before I had a license plate. Yes, the state of Washington requires a front mounted license plate, AND someone drilled the bumper to install it before I got it
This was that summer.. it was sporting a cold air intake and a muffler delete.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-30-2019, 02:34 AM   #2
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
Badass. That’s a big cam. Did they try and sell you cylinder heads?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 05-30-2019, 06:13 AM   #3
Chris49066SS
Drives: 2010 SS L99
Thank you! Actually, no, they asked if I wanted to have them rod mod my intake manifold, but my budget had already maxed out. They put on some head gaskets from Cometic and were able to bump the compression up to 11.1 without milling. Heads would've been awesome but it just wasn't feasible that time. It still isn't, after this little batch of upcoming mods (new headers, LOD intake manifold and CHE trunnion upgrade). I will likely wait to do the heads until I do my fuel system.
Old 05-30-2019, 06:41 AM   #4
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Very nice ET!
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 05-30-2019, 08:42 AM   #5
Chris49066SS
Drives: 2010 SS L99
Thanks John. I am aiming for a similar build as yours. Looks pretty solid, man!
Old 05-30-2019, 05:01 PM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
thats what i said moments after i bought the car. ain't it funny
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-30-2019, 05:10 PM   #7
Chris49066SS
Drives: 2010 SS L99
Heh for sure
Old 05-30-2019, 07:25 PM   #8
13_SS_RS
Drives: White 2013 SS/RS l99
I’m glad you posted this. I do major lurking on here and every time I see your sig in a thread with that burnout pic , awesome car man!!! I see you are in tn, who did your cam install and tune? Every shop around Atlanta I talk to always wants to get rid of vvt. Gpi is 12 hrs from me, would be nice to find a shop closer to home that can handle a vvt cam
Current: 2013 summit white Camaro 2SS l99
CAI, long tubes, ported tb, tune
Previous: 2008 jet stream blue Corvette Z06
Airraid, Corsa, MGW shifter SOLD
13_SS_RS is offline   Reply With Quote
Old 05-30-2019, 07:28 PM   #9
sixty9fordkiller
Dont get rid of the VVT if you drive it on the street. Its a plus because of valve timing flexibility
If you're going full send, then get rid of it
Sent from my SM-G975U using Tapatalk
Bone Stock
Old 05-30-2019, 07:29 PM   #10
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Cool, Chris. Glad to see you starting a journal/build thread. Your car hauls ass dude!!! That 60' blows my mind, but your ET is very impressive as well. Looking forward to updates.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 05-30-2019, 07:35 PM   #11
sixty9fordkiller
yes. that 60'
Bone Stock
Old 05-30-2019, 08:58 PM   #12
Chris49066SS
Drives: 2010 SS L99
Thanks dude! Yep those were my Nitto NTO5Rs that I did that burnout on. After an embarrassing performance at a local 1/8 mile track, I got a Hurst line lock and vowed to smoke the living daylights out of the Nittos to heat them up enough for November track conditions. "This time I am gonna do a burnout from hell" was the quote that led to the burnout featured in my sig pic below.
GPI did my cam, and Ryan Stevens did my tune. He did a street and dyno tune. Top notch shop!
Thanks Z, thanks Fordkiller! I'm gonna post some more updates as soon as they come.
Old 05-30-2019, 09:30 PM   #13
Chris49066SS
Drives: 2010 SS L99
Chapter 1 2015-2017
This was the first mod to my car, very expectedly, as I was not familiar with the plethora of aftermarket goodies and support for the 5th Gen Camaros. The tried and true from the 90s, watching Horsepower TV and wandering AutoZone looking for air filters and wondering how much horsepower some Royal Purple Oil would free up...Get a K&N!
A few months went by, and I went ahead and got these 1 7/8 long tube headers from Texas Speed & Performance. They looked awesome next to the stock boat anchors, and were so much lighter! I chose the catless option, and a buddy and I got them installed in a little less than 2 hours. Such an easy mod, and when we fired it up (I already had done the muffler and resonator delete, mind you) I grinned from ear to ear. Now I was loud, right?
Shiny new headers, ironic picture though, later in the journal when I catch it up to current, you will see why..
We took it out to the back 40 for a little sound test, and here it was, a straight piped stock L99 with only long tube headers and a cold air intake...eeghh
Now given that, just imagine the AFM kicking in. until I found the way to get around it. But really, all I needed was a tune. Maybe a performance chip would do the trick, right?
Fast forward to the summer of 2018. Here is one of my 1/8 mile passes a couple of months before camming the Camaro. I was lined up against a C5 at the local track. The only difference now was that I was running open headers instead of straightpipe. I don't have the slip anymore, but the et was 8.5@8?mph
Old 05-31-2019, 09:02 AM   #14
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Chris - Awesome build buddy. You are certainly the master at putting the right parts together to go very fast. That 60' and ET are incredible. I'll be following the build thread for sure! Hurry up with chapter 2!!! - Jeff
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
