Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 08-18-2022, 10:40 PM   #2647
Jwelsh
Drives: 2014 Camaro SS/RS
Sick build and also amazing write ups and links. Best write ups I’ve seen.
Jwelsh is offline   Reply With Quote
Old 08-21-2022, 05:08 PM   #2648
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Thank you! Still going strong -- nothing to build anymore-- just drive for fun!
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 12-31-2022, 03:04 PM   #2649
hammdo
hammdo's Avatar
Hard to believe it’s been 8years since I did the ADM LSA install. These cars are amazing…
-Don
747 RWHP 794 RWTQ
Old 12-31-2022, 07:09 PM   #2650
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
-Don
Time flies for sure!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 01-01-2023, 08:47 AM   #2651
-Don
The good ones stand the test of time
Old 06-30-2023, 11:35 PM   #2652
RubyCamaro
Jan
RubyCamaro's Avatar
Old 07-02-2023, 11:21 PM   #2653
hammdo
hammdo's Avatar
Hey Jan! Thanks for stopping by!
Hope retirement is going well for you!
-Don
747 RWHP 794 RWTQ
Old 01-25-2024, 08:52 PM   #2654
hammdo
hammdo's Avatar
Flying more than driving - she’s still doing great and super fun to drive. Miss the old days when this site was so active and innovative.
Enjoy what we have…
-Don
747 RWHP 794 RWTQ
Old 01-26-2024, 02:07 PM   #2655
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
Enjoy what we have…
-Don
Hey hammdo, I don't know you, but I've read a lot of your post and used a lot of your content in working on my Camaro.
I just wanted to say thank you! And I too, wish I would've been around during this sites' prime.
Brian
SlowLS1 is offline   Reply With Quote
Old 04-03-2024, 10:24 PM   #2656
hammdo
hammdo's Avatar
Thanks!
I've noticed C5 lately is not showing my images -- They're still online -- don't know what changed on C5...
Just a heads up if someone is looking for them...
-Don
747 RWHP 794 RWTQ
Old 04-04-2024, 07:55 AM   #2657
Ashen 6.2
Ashen 6.2's Avatar
Thanks!
-Don
Hope all is well Don! That would be a shame to loose all those images. I use them often for reference.
Roy
Old 04-09-2024, 07:26 PM   #2658
hammdo
hammdo's Avatar
Yeah, it happens whenever they do an update. Not sure why…
-Don
747 RWHP 794 RWTQ
Old 04-16-2024, 02:20 PM   #2659
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
JRE trans tube
Just finished the install of the Jannetty Trans Dipstick assembly. Really nice setup.
So, a couple of things to note:
I have headers and the O2 extensions so I had to maneuver them along with the wire harness that is just above the location where the tube goes in.
First, I remove the B&M dipstick and cleared the area (note, I removed the sparkplug wire on #8)
then, while underneath, I move the wire harness up to give the tube clearance:
With the tube in, that wire is going nowhere...
next, I applied a little trans fluid to the seal and placed it back on the tube:
Next, I removed the one bolt on the bellhousing right above the starter:
Once the bolt was removed, from the bottom, I manipulated the tube so it would make its way to the engine bay -- you just have to fish it up there, making sure all wires are cleared and no impediments. I'd consider 'taping over' the opening at the top (my engine bay is pretty clean but as a precaution its not a bad idea):
With that partially located, verify wires are cleared, nothing pinching around the headers, then slide the tube seal and tube inside the opening in the transmission -- make sure it bottoms out (Notice I pushed the wires up and out of the way of the dipstick tube?):
Now bolt in the bracket (tighten the bolt 30 to 35 ft lbs per Ted) -- notice the starter wires and how close they are to the bracket?:
I then ti-wrapped the wires and connectors to keep them away from the header:
Put in the dips stick (notice I rotated it 180° to keep it out of the way):
Verified everything and fired it up!
NO LEAKS and this works 100x better than the previous setup -- WELL worth the effort.
Overall, took me about an hour since I had to remove the B&M version (and while I was at it, replace the cabin filter since I was in there).
GREAT product and install was not bad @ all! Looks like it will read the level just fine -- I just need to test it properly by getting the temps up -- weather sucks right now so I'll probably have to just let the car run for a while and ck it then.
My only issues were the spark plug wire is just touching the tube -- but I think a small correction on it will fix that. I'd also consider 'notching' the bracket for the starter wires, just to give a bit more room there -- but these are the ONLY things I've found. I'd also consider adding a hole in the bracket so a tiewrap can be used too (maybe 2 holes)...
-Don
Don,
You don't happen to still have these pictures of your install do you? I tried for a couple hours to get this tube in and couldn't get it done. I felt like the wire harness and starter cable were in the way and no matter where I moved them i couldn't make it happen.
Thanks,
Tyson
Lnch Mny is offline   Reply With Quote
Old 04-18-2024, 10:25 PM   #2660
hammdo
hammdo's Avatar
The site is no longer showing my pics - don’t know why - I guess since it’s not HTTPS, they sure need to fix that.
Pics are in url tags - I checked.
Let me check the page again…
-Don
747 RWHP 794 RWTQ
