08-21-2016, 05:09 PM | #15 | |
Drives: 16' Camaro E-Force SS Join Date: Jul 2016
08-21-2016, 06:35 PM | #16 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Hmmm not sure if your going the right way.
If you want that power why not get a Zl1, its all done for you with a warranty. The SS has more then enough power for the street to get you into trouble burning rubber around town. In my opinion I could see an SS maybe supercharged if your a track nut.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
08-21-2016, 08:42 PM | #17 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Aren't Magnuson cars running high 10s and the ZL1 numbers are low 11s? Word-of-mouth around here at shows is the Magnuson is the best aftermarket SC option. Still seeking SC knowledge myself...
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
08-21-2016, 09:46 PM | #18 |
08-22-2016, 03:19 AM | #19 |
Drives: 2016 2ss Join Date: Aug 2016
Looking to do mine this winter but im not certiain how i feel about throwing the drivetrain warranty out the window..
Side note im also from RI |
08-22-2016, 07:10 AM | #20 |
Drives: 2017 Summit White 2SS Join Date: Apr 2016
08-22-2016, 02:35 PM | #21 |
Johnston. I pass through Cranston pretty often. Looking forward to supercharging but Currently im looking for a place to store it the next couple months. Going on a short deployment and really don't want to leave it unattended outside.
08-22-2016, 02:55 PM | #22 |
Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
With radials and exhaust work. Tires make a huge diff in track times.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
08-22-2016, 04:12 PM | #23 |
Drives: Chevys at the limit Join Date: Nov 2010
I vote Magnuson all the way! Just that with no other bolt on's it made 530 HP and 588 lbs torque . Just saying if your going to supercharge your car go with Magnuson and their standard 3-year/36,000 mile Warranty on the supercharger hardware and standard 1-year Limited Warranty on electronics. You can find more info in our thread.
Best regards, Kayla L. 801.545.4215 |
08-23-2016, 01:47 AM | #24 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
08-23-2016, 07:11 AM | #25 |
08-23-2016, 08:12 AM | #26 | |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
08-23-2016, 10:00 AM | #27 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
There are really only 3 PD superchargers available for the LT1 right now: Edlebrock E-force, Magnusson Heartbeat and ADM LT4 conversion. The whipple has not been produced yet and I'm sure based on the previous stuff from whipple it will be a good supercharger. The whipple will be a 2.9, the edlebrock and Maggie are 2.3's and the LT4 is a 1.7. These figures are based on air volume per rpm.
The problem is the LT1 is 11.5 compression and can't take a whole boatload of boost unless you give it some kind of octane boost. Most of us are daily driving and need to run on 91 or 93 e10 blended gasoline. The reality is at 5-7 pounds of boost the LT1 engine is comfortable. Beyond this it gets sketchy. You also run out of fuel but it is a lot easier to change fuel pumps than pistons and compression ratio. So based on all of this, if you want to bump the LT1 with a little power I think the LT4 supercharger can do it just as easy as anything else on the market for less cost and less parasitic loss when the supercharger is running in bypass mode most of the time (efficiency is the main reason GM developed it). I kind of feel that the engine needs a compression ratio change or the car needs to be converted to race gas/E85 to use the potential of the larger superchargers. If you want to go with a 2.3 the Maggie has a better intercooler system and will have slightly lower intake temps (make a little more power). If ADM does your build it will be awesome. ADM has done a lot of work for me and I can tell you they are one of the best shops in the country.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
08-23-2016, 10:05 AM | #28 |
"Lohla"
Do more research. The Maggie Heartbeat is far and away the most advanced PD Blower on the market at present. It's cooling is superior enough in itself to choose the Maggie.
Good luck!
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
Tags |
supercharger, supercharging |
