03-26-2021, 03:39 PM | #1 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
SS 4 piston to ZL1 1LE brakes questions
So I just grabbed a set of ZL1 1LE calipers for my 4 piston SS
Can anyone point me to which rotors I need? Anything else other than new hardware? Do the ABS sensors have to be replaced? And last but not least, when I install all this is the car going to need to be programmed or flashed? |
03-26-2021, 10:18 PM | #2 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
ZL1/ZLE (front) Rotors:
GM#84271643 ACD#177-1247 From my experience... No No No
03-27-2021, 10:14 AM | #3 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
You will also need ZL1 brake hoses.
Baby Blue
03-29-2021, 09:11 AM | #4 |
j1ss
03-29-2021, 09:12 AM | #5 |
j1ss
03-29-2021, 02:07 PM | #6 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
So, if you have an SS (non-1LE), to convert to ZL1 brakes you need: -ZL1 calipers, front and rear -ZL1 rotors, front and rear -New crush washers for the brake lines -Brake fluid The hydraulic units between SS (all) and ZL1 (all) are the same part. The Dynamic controls are a bit different between the SS, SS 1LE, ZL1 and ZL1 1LE though. You won't have an optimized system, but everything should work fine. |
03-29-2021, 04:41 PM | #7 | |
Drives: 1LEs Join Date: May 2009
03-29-2021, 09:39 PM | #8 | ||
And certainly pads! Spring and bridge bolt would be part of your caliper hardware kit. Contact Matt at https://wildhammermotorsports.com and you won't be missing anything!
03-30-2021, 01:19 AM | #9 |
Just extra weight.
Edit: to add... the SS/SS 1LE rear pads do fit into the ZL1/ZL1 1LE rear calipers and can be used, but less swept surface. The front SS track rotor shield can/should be used. Last edited by Mountain; 03-30-2021 at 12:09 PM. |
04-01-2021, 10:04 AM | #10 |
j1ss
appreciate the help everyone
04-01-2021, 10:04 AM | #11 | |
j1ss
04-01-2021, 10:17 AM | #12 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Basically all the brake control cals won't be 100% accurate anymore, primarily ABS. It will still function, it just won't be 100% refined as it was with original parts.
2017 SS 1LE.
04-01-2021, 01:12 PM | #13 |
j1ss
Thats what I figured but do you think it'd be to the point where you'd notice it aggressively braking on track? or no
04-02-2021, 09:12 PM | #14 | |
It's kinda the same idea as switching tires or wheels to something not OE. Sure the control systems won't be 100% optimized, but it doesn't necessarily make the car undriveable.
2017 SS 1LE.
