11-30-2017, 03:18 PM | #1 |
Drives: 2017 A10 ZL1 Join Date: Apr 2013
ECU Swap
I have a 2017 Zl1 I want to get tuned.
Is it possible to purchase a secondary ECU that I can swap into the car and get tuned while keeping the stock ECU untouched? That way if anything goes wrong I can swap back to stock and there won't be a raised flash counter. Just curious. ~Jason
2017 Camaro ZL1 Coupe Black |A10|PDR|NAV|
11-30-2017, 10:16 PM | #2 |
Drives: 2017 Camaro 2SS Convertible Join Date: Sep 2017
Anyone have any ideas on this. That's a good question.
11-30-2017, 10:17 PM | #3 |
Waiting on Glen. He knows everything.
11-30-2017, 11:15 PM | #4 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Yes. Discussed this with Cunningham at one point. Really the ONKY way to ensure a dealer will never know you had a different tune flashed. Let us know what they cost when you find it. Surely $$$$$$$!!!!!
12-01-2017, 10:02 AM | #5 | |
The description reads: "Description: Tahoe, Yukon, Escalade. Suburban, Yukon XL. Escalade ESV. Corvette. Camaro. XTS. All. 4.3L. 5.3 & 6.2L. 6.2L supercharged. Sierra, silverado. With turbocharger. 3.6L, 3.6L twin-turbo, with twin-turbo, labeled 12672537." Based on that I would assume that's the one for the 17 zl1 also.
12-01-2017, 02:01 PM | #6 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Available on Amazon, RockAuto, etc. Question is how do you get it programmed?
12-01-2017, 02:56 PM | #7 | |
That would mean the next time they plug into the car they look for the new computer id but instead see the old one. It may raise some red flags. Not sure if that's the case or not.
12-01-2017, 07:38 PM | #8 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
You can buy a new ECM from rock auto. They have them in stock. I’ve replaced one already, it cost around $300 IIRC. I had a dealer flash it to stock, brought it home and flashed my ProCharger tune into it. I have my stock one that may or may not be bricked sitting in the box.
If you buy another ECM, you can have them flash it under customer pay and it doesn’t get tracked like warranty work. You would then have two that you can do as you please....you can also tune both with HPTuners since you have the VIN licensed. It’s basically the expensive way of cloning and ECM.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
12-01-2017, 07:47 PM | #9 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
IF you havent tuned your car yet can you just buy a new computer and replace your ECU with that one and have your tuner flash a tune onto it, and never actually touch the OEM ECU?
12-01-2017, 07:48 PM | #10 | |
This would be awesome if my dealer will do this.
12-01-2017, 07:52 PM | #11 |
Car needs to be there. I trailered it over and then we took the blower belt off to reload it. Literally took 30 minutes. Should be quicker if yours is still 100% stock. Put the new ecm before you get there. IIRC the dealer charged me $130 for the flash. It was definitely reasonable since the shop that bricked my ECM wouldn’t do anything for me, but that’s a whole other story.
12-03-2017, 12:06 PM | #12 | |
12-03-2017, 06:41 PM | #13 |
The mileage is stored elsewhere. When I did mine, it rolled in with the new, unflashed ecm and when it pulled out the mileage was correct.
12-05-2017, 11:50 AM | #14 | |
If the dealer Syncs one the other becomes unusable. They have security key that must be synced to all other modules in the car. Ted.
www.jannettyracing.com
